Can an SCR handle high voltage?
12 replies · 5K views · last reply
durkmusic
I'm looking on digikey for an SCR and there is a parameter that concerns me:
Voltage - On State (Vtm) (Max)
It seems the maximum voltage rating for this parameter is 3.7V. I must be misunderstanding what this parameter means. Is there somewhere I could look up what it means?
I plan to run a 12V motor pulling 3A and use the SCR as a switch instead of a big bulky relay. But if the max voltage is only 3.7V, then I must look for an alternative solution.
Well that scr is not going to be much use to you.
The on state voltage is the voltage across the device when it is on ie conducting.
So if you SCR drops 3.7 volts you will only have 8.3 volts left for your motor.
further the scr will be loosing 3.7 *3 = 11 watts.
By contrast the contact resistance of a good relay is measured in milliohms so pretty well all of your 12 volts will appear across your motor.
Page 8 here
http://www.onsemi.com/pub_link/Collateral/HBD855-D.PDF
You sure it's not the maximum gate trigger voltage, Vgtm, they're referring to?
That's VGM in my reference.
Actually, your reference for gate trigger voltage is VGT
The gate dc voltage required to produce the gate trigger
current.
Edit: You're right for the max. Sorry.
It sounds like that is probably an absolute maximum rating at absolute maximum current. Assuming that the current rating for your SCR has been correctly chosen, then the actual on-state voltage under normal operation will probably be in the 1.0 to 1.5 volt range.
BTW. Is this a 12V DC motor? How do you plan to turn the SCR off?
it is a 12V motor and i planned on turning it off by forced commutation.
That's getting ambitious, but would make an interesting project. :smile:
You could search for an SCR with a lower voltage drop, or maybe you could change to a power supply of say 13.5V on the assumption that you'll lose 1.5V or so across the SCR?
Is your goal here to get electronics experience, or to construct a reliable working circuit for a larger project? If the latter, then I side with those suggesting a relay as an off-the-shelf solution.
This is for experience. The goal is to control high current loads with a micro controller. Motors, large DC light bulbs, etc. Basically all with semiconductor devices (aka no relay). A relay is the obvious choice but I've already completed operating these loads using a micro controller and a relay. My goal is to do this without using a relay. It seems to be very tricky to do but I like challenges. I'm not getting much support on this project and I don't know why but I will continue on! :D
Here is what I have as a basic idea:
Schematic of an SCR control circuit: 12 V source V1, R1 1kΩ and R2 1kΩ, capacitor C1 1uF, diode D1 2N1599, transistor Q1 2N3417, and R3 150Ω and R4 1kΩ linking two microcontroller I/O pins.
I don't know how to size the cap or r2 but r1 will be the load. the SCR I am experimenting with now is a S6020L and the transistor I am experimenting with is a MJH6287. It's a PNP. I meant to order an NPN version but I got em mixed up. I want high true but pnp gives me low true. Not really a problem just more of a slight inconvenience to the way I normally think of things. Anyways. Is my though process on the right track here or am I trying to do something impossible?
Basically a positive pulse from the microcontroller will turn the circuit on and a different pulse from a different pin of the microcontroller will cause the transistor to close and force current the opposite direction of the circuit for a second causing the scr holding current to go low enough therefore turning it off.
That's the basic idea, and interrupting 11 mA in a resistive load should be no problem. :smile:
But what happened to the 12V 3A motor?
Oh. I'm sorry about that. What I was trying to say is that R1 will be REPLACED with whatever load I want. All 12V loads ranging from 3A-10A or more. Idk yet. The goal is the 12V 3A motor. Sorry about the confusion. I guess I should have just put a motor schematic symbol instead of the load, flyback included. I just threw down a basic idea but yes that r1 will be REPLACED by a real load.
durkmusic said:
Bump :(
Just use the correct tool for the job (switching 10A @12V DC), a MOSFET.
If you're doing this to learn about SCR's and forced commutation then that's fine (though you'll need to beef up your commutation circuit to switch 10 amps), but let us know what the purpose is here.
