Can area of a triangle be 0.5(c x a) instead of 0.5(a x c)?
  • Thread starter Thread starter coconut62
    Area Triangle
The area of a triangle can be expressed as 0.5 times the magnitude of the cross-product of two vectors, represented as (1/2)||A x C|| or (1/2)||C x A||. The direction of the vectors does not affect the area calculation since both expressions yield the same magnitude. This relationship holds true regardless of the angle between the vectors, provided angle B is not specifically 90 degrees. The discussion clarifies that the right-hand rule and vector directions are not relevant to the area calculation itself. Overall, the area formula remains consistent across different vector arrangements.
coconut62
Please see the image attached.
Does that have anything to do with directions? The right-hand rule?
Mathematics news on Phys.org
ca = ac, so yes.
Not in that figure, unless angle B is 90 degrees.
using the magnitude of the cross-product of two vectors to find the ar
If you mean
Area of triangle = (1/2)||A x C|| = (1/2)||C x A||
as in, using the magnitude of the cross-product of two vectors to find the area of the triangle between them, then yes.
mark.watson said:
If you mean
I didn't see the second part of your question. The direction of ||A x C|| or ||C x A|| doesn't matter because they have the same magnitude. That is why (1/2)||A x C|| = (1/2)||C x A|| is true.
Thank you very much.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
