Can Base 10 Logs be Evaluated Without a Calculator?
  • Level: Undergrad
  • Thread starter Thread starter Flexington
    Base
18 replies · 6K views · last reply
Flexington
Im looking for a method of evaluating large logs without the use of a calculator, such as,
log102750.
Using properties of logs i can reduce the problem to 750*10y=2.
However this requires an estimate on the value y which is going to incure a significant error in my final result.
Im guessing I am overlooking something?
log102750.
log10(2750)= 750 log10(2)
Also,
[tex]2^{10}\sim 10^3[/tex],
Thus
[tex]\log_{10}(2^{750}) \sim \log_{10}(10^{225})=225[/tex]
I'm curious how good this approximation actually is...
micromass said:
Also,
Thus
Very close! Maple gives 225.77
log102750.
We used to use log tables.
... but now tables are made out synthetic material. Sorry, couldn't resist.
George Jones said:
Maple gives 225.77
This was silly. From what mircromass wrote,
[tex]\log_{10}(2^{750}) = 225 + 75 \log_{10}(1.024)[/tex]
spot on micromass. Can your method be generalised?
I don't know any generalization. The [itex]2^{10}=10^3[/itex]-trick is something I learned from professor Daubechies. I'm guessing you could generalize it with a instead of 2, but then you would need to find suitable n and m such that [itex]a^n=10^m[/itex]...
If 2^10 really equaled 10^3, then the log102 would equal .3. Being an electrical engineer, I happen to know the log102 would equal .30103...
Other than memorizing more of the log table, you can either derive it from the taylor series log(1+x)=x-x^2/2+x^3/3... or interpolate from a log you do know using calculus. Say you know log(a), then the log(a+x)=log(a)+x/a+...
For example, I know the log(10)=2.3, so therefore log(11)=2.3+1/10=2.4. Close enough for engineering anyways.
in shakespeare's time, one could get one's servants to do it!
from http://www.enotes.com/romeo-and-juliet-text/act-iv-scene-iv" …
SECOND SERVANT:
I have a head, sir, that will find out logs :wink:​
When I wrote the above, I had in mind calculating by hand the first couple of terms from
but then I realized that
is also needed. Given this,
[tex]\log_{10}(2^{750}) \doteq 225 + \frac{75}{2.3} \left(0.024 - \frac{0.024^2}{2}\right),[/tex]
which is tedious, but not difficult, to calculate by hand, and which gives a very accurate result.
The natural log of the first twenty numbers have pretty good one digit approximations.
ln2=.7 ln3=1.1 ln4=1.4 ln5=1.6 ln6=1.8 ln7=1.95 ln8=2.1 ln9=2.2 ln10=2.3 ln11=2.4 ln12=2.5 ln13=2.6 ln14=2.65 ln15=2.7 ln16=2.8 ln17=2.85 ln18=2.9 ln19=2.95 ln20=3.0 ln(21)=3.05
If you need more accuracy, you can just use calculus.
And, of course, you can always do a binary search for more precision on one of them:
If exp(2.95) > 19 but exp(2.94) < 19, then ln(19) must be in between... oh, let's try some number in the middle...
Say I'm sitting in an art movie and need to know 7^18. 7^18=e^35.1=(20^11)*8=2^14*10^11=16*10^14. My calculator says 1.628e15. If you need more accuracy than this get a calculator.
What's the smallest number where my method loses monotonicity? That is you'll get a smaller log from a bigger number than from some smaller number? I have ln(3125)=ln(5^5)=5*1.6=8.0. ln(3072)=ln(3*2^10)=1.1+10*.7=8.1.
The ln(5) is really 1.61 so the ln(3125) is really 8.05. The ln(2) is really .693 so ln(3072) is really 8.03.
This was hilarious. (The movie must have been Aronofsky's "Pi".)
I did a silly suggestion, anyway, because for an iterative approach you'd need a calculator anyway.
I'm wondering if there is such thing as monotonicity here; results are up or down the real value mostly depending on which direction the initial 1-digit approximation was rounded.
I'm wondering if there is such thing as monotonicity here; results are up or down the real value mostly depending on which direction the initial 1-digit approximation was rounded. /QUOTE said:
ln(48)=4*0.7+1.1=3.9 ln(49)=2*1.95=3.9 ln(50)=2.3+1.6=3.9.
It isn't too hard to realize that in real life ln(50)>ln(49)>ln(48). But rounded to one digit there's no incongruety. Only slightly harder to realize that they must be 1/50 or .02 apart. Anyways what I meant was where do you see an obvious error because the log of a smaller number is larger than the log of a bigger number.
It's probably worth memorizing the log of small primes to better than one digit accuracy. Because when you take 2^10, you lose a digit of precision. If you take 2^100, you lose two digits of precision.
