Can capillary forces act upside down?
Capillary forces can indeed act in an upside-down scenario, where a drop of water hanging from a ceiling can be drawn into a straw. When a long straw is inserted into a small hanging drop, the water will continue to rise until the drop is depleted, potentially spilling out once it reaches the straw's end. In the case of a large drop with a short straw, capillary action will initially draw water in, but it will eventually fall out once the water reaches the straw's end, as surface tension rather than vacuum holds it in place. The behavior of the liquid depends on fluid properties and the dimensions of the capillary structure. Understanding these dynamics is crucial for applications involving capillary action.
philip041
This is fairly amateur but I'm not an engineer so:
If you have a drop of water on a table and you stick a straw in it some of the water goes up the straw until gravitational force equals the capillary force.
Am I right in saying, (generally):
1) If you have a small drop of water hanging from a ceiling and stick a long straw in it the water starts going in it will keep going until there is no drop left and keep going until it reaches the end of the straw and then fall out the bottom.
2) If you have a large drop with a short straw capillary forces will draw water in but once water reaches the end of the straw it won't fall out the bottom because there is still some drop left at the top, so no air can get into tube?
Cheers
Interesting question. My only experience with capillary action was that we relied upon it to suck a thin adhesive between pieces of acrylic for manufacturing purposes. That was a little different than a tube. Regardless of orientation, the liquid would go only to the edge of the material and stop (unless way to much was applied, in which case it would spill out).
it may or may not fall, surface tension might just hold it in equilibrium. it depends on fluid properties & the capillary dimensions.
No, it ll continue falling down, until condition (1) is reached(small drop left), vacuum isn't holding the fluid in the capillary, surface tension is.
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
