Can dispersion of light take place through lens?
Dispersion of light can occur through lenses, including both convex and concave types, as they can scatter white light into its constituent colors. This phenomenon is related to chromatic aberration, where different wavelengths of light are refracted by varying amounts. The discussion highlights personal experiences with high-index glass lenses that exhibit significant dispersion, allowing for visible spectral effects, particularly at the lens edges. Observations include distinct spectrum lines from street lamps, such as sodium and mercury vapor lamps. Overall, lenses can indeed disperse light, leading to interesting visual effects.
aditya ver.2.0
Can dispersion of light take place through lens, i.e. can lens (incl. Convex and Concave) scatter white light into its constituents?
Science news on Phys.org
Do a little reading on "chromatic aberration."
I once had eyeglasses that used a then-new type of glass with a higher index of refraction which allowed the lenses to be thinner. (I'm very nearsighted and have to use a strong lens prescription.) That glass also had a rather high dispersion, so when I looked at a street-lamp through the outer part of the lens, near the edge, I saw a nice little spectrum. I could even make out spectrum lines in sodium and mercury vapor lamps!
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
