Can I Build a Simple Optical Device with Just Two Magnifying Glasses?
  • Thread starter Thread starter AznBoi
    Lens Project
Building a simple optical device using just two magnifying glasses is feasible and can be done affordably. Telescopes and microscopes are highlighted as the easiest options for this project. Participants share that constructing a telescope with two magnifying glasses is straightforward, and there are resources available for guidance. There is interest in finding affordable magnifying glasses for purchase. Overall, the discussion emphasizes the simplicity and cost-effectiveness of creating basic optical devices.
AznBoi
Everyone in our class needs to build a lens optical device such as a projector, camera, copier, telescope, microscope, solar cooker, etc. We will need to include a ray tracing diagram. Has anyone ever made a simple device with lenses? What do you think will be the easiest and cheapest? Thanks
Telescopes are very easy and cheap. A microscope would be relatively easy as well. Solar cooker? Hah.
Any other opinions?
I've read some informational articles about building telescopes and it says that all you need is 2 magnifying glasses? Is it really this simple? If so, I'm going off to the store to buy magnifying glasses. =] Does anyone know where they sell cheap ones at? Thanks.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
