Can I put a PC on top of a marshall half stack guitar amp?
  • Thread starter Thread starter CleanerTax
    Amp Guitar pc
Placing a PC on top of a Marshall half stack guitar amp is generally considered safe, as the distance from the speakers minimizes potential issues. Concerns about vibration damaging hard drive bearings are valid but unlikely, especially at low volume levels. Modern hard drives are well-engineered to withstand minor vibrations, and magnetic fields from the speakers will not affect the computer. Users have reported successfully using laptops on amps without problems, even at high volumes. Ensuring the PC is secure to prevent it from being knocked off is the main practical consideration.
CleanerTax
Hi, I wanted to ask if there would be a problem or two if I placed my pc on top of the head of the marshall half stack amp, the harddrive is about 65ish cm away from the center of the speaker (4x12inch speakers) and the power supply of the pc is about 50ish cm away from the center of the speaker, The amp is 175 watt, and the power supply is 760 watts. I read that it would probably won't cause any problems but I want to be sure about it. Thanks
I can only think of possible damage to the Hard Drive bearings if the vibrations of the cabinet are excessive. However, hard drive mechanisms are very light and well balanced so there may be no trouble at all. Magnetic fields from the Speaker Units will have no effect and the heat produced would be no more than from your lap when using the PD watching TV.
There is an apocryphal tale about the hard drives that were installed (quit a few years ago) below point of sale terminals in a national chain store. They were all failing after a very short operating time. It turned out that the cash drawer was closing with a bang and shaking the drive each time. But that was then and hard drives have come a long way since. Of course, if you are as rich as Croesus, your mass storage will be Flash Memory with no moving parts.
Oh, ok thank you very much, I am not worried abotu the vibrations since I don't turn the amp volume all the way, not even half the way up, the maximum is like 1/4, and I can't notice any vibrations on the head, I was worried about the magnetic field or something affecting the computer or the speakers, but thank you very much!
When floppy discs were in their infancy (100kB capacity !), it was sometimes possible to affect the data with a magnet. Nowadays the magnetic patterns are impressed by very high local fields in the head gap. They are much higher than any loudspeaker could ever produce. The only region of high field is down inside the speaker unit where the voice coil sits.
I have used my laptop setting on top of several guitar amps I have with no issue. The laptop is running effects software and other midi stuff. Another laptop sets on the amp for the piano at times with the amp turned up to club volume with no issues also.
All my desktop style computers are a bit large to use in that way but I don't think that it would create any issues.
Keeping the computers from being knocked off the amp is something you need to pay attention to.
Cheers,
Billy
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
