Can I remove rust by applying current?
  • Thread starter Thread starter fysik
    Current Rust
Applying current can help remove rust from metal through electrolysis, but it does not restore the original mechanical strength of the substrate. The process can convert metal oxides back to metal, but the resulting material tends to be a powder rather than a solid part of the metal structure. While the method can effectively reduce corrosion, it may not provide a lasting solution for structural integrity. Users have reported success on a small scale, but the re-integration of rust into the base metal is not achieved. Overall, electrolysis can be a useful technique for rust removal, though it has limitations.
fysik
hello
let's say we have a rusted piece of metal
if I apply the correct current
can I force the oxygen in the metal oxide to be removed and leave only the metal intact?
thanks
Applying the proper potential can retard corrosion, and the opposite potential can greatly speed up corrosion.
But the oxides are not great conductors, and even if you get the unozidized metal atoms back, they will no longer be part of the substrate in the sense of adding mechanical strength - more of a powder on top.
There is a website giving a method of removing rust using electrolysis, http://myweb.tiscali.co.uk/andyspatch/rust.htm.
I have tried it on a small scale and it will often work, but it does not re-incorporate the rust into the base metal, as has been stated.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
