Can Kummer Extensions of p-adics Prove a Contradiction?
  • Thread starter Thread starter yonat83
yonat83
Hi everyone,
This is my first post here, so first of all, Congrats on this website, it seems very instructive and usefull!
I m currently studying p-adic number fields for my master degree and have a problem I can't seem to resolve.
Consider the p-adic local field F=Q_3 and its 2 extensions k1=Q_3(z_13) and k2=Q_3(z_3), when z_n denotes a primitive n-th root of unity.
Since (3, 13) = 1, k1 is unramified over F and k2 is obviously totally ramified over F.
Moreover, [k1:F] = 3 is the order of 3 in the multiplicative group Z_13* since 3^3=27=13*2+1.
on the other hand [k2:F] = 3-1 = 2.
Both are cyclic sub-extensions of k1k2 / F
Now, consider the extension k1k2 / k2. This is a cyclic extension of degree 3 and by ramification theory, its unramified.
Now by Kummer theory, since z_3 is in k2 its generated by some root a^(1/3) for some a in k2. We can assume a is integral.
But now, reducing mod P, when P is the maximal ideal of k2 over (3), the equation x^3 = a (mod P) has solutions in the residue field of k2 since the power-3 map is just the frobenius automorphism on the residue field of k2. Hence the residue field extension corresponding to k1k2 / k2 is trivial and then k1k2 is totally ramifie over k2! That's a contradiction...
So there is abviously a mistake somewhere in my "proof" but I can't find out where it is...
I could really use some help,
thanks a lot
Yonathan
You seemed to have argued the generator of k2 lies in the residue class field of k2, but haven't said anything about the generator of k1.
I don't care much about k1: the only thing I need to know about it is that it is cyclic unramified of degree 3... I know for sure there is such a field over F from class field theory for exemple
But you don't have appeared to use k1 at all.
Oh, I think you were assumed that any degree three extension could be defined by a polynomial of the form
f(x) = x3 - a​
? That is definitely false -- no polynomial of that form is ever irreducible in the residue class field of Q3 or its finite extensions, and so any algebraic extension of Q3 whose residue class field is a degree 3 extension of the residue class field of Q3 cannot be defined by a polynomial of this form.
Ok, but k2 contains a primitive 3 root of unity, doesn't Kummer theory exactly says that 3-cyclic extensions of k2 are ALL generated by such a polynomial?
Sigh, this question is going to bother me all day. :frown:
Ok, so I think the problems comes from the fact that reducing the equation x^p-a modulo P does NOT give a defining equation for the coresponding residue field extension.
Then the question arising is how can one determine such a defining equation on residue fields, given the local extension? More generaly, how can one compute ramification groups of Kummer p-extensions?
Right. I think it in terms of rings of integers -- for example, the ring of integers in the number field \mathbb{Q}(\sqrt{5}) is not R_1 = \mathbb{Z}[\sqrt{5}]. The residue class field at 2 is the finite field with 4 elements, but the latter ring only generates the subfield of 2 elements.
Of course, if you took the full ring of integers R_2 = \mathbb{Z}[(1 + \sqrt{5})/2], then reducing modulo 2 would, in fact, give the finite field of 4 elements.
The index of R1 in R2 is 2, so 2 is the only prime over which there is a problem. (Of course, this could also be seen directly)
IIRC, some of the prime factors of the discriminant of a polynomial tell you where the bad behavior described above can occur, and the remaining factors tell you where ramification occurs.
So, Artin-Schreier theory tells us about the degree-p extensions of a finite field of characteristic p.
I'd like to say the following statement is true, but my memory of padic fields is fuzzy so I'm not sure:
There is a one-to-one correspondence between finite, unramified extensions of F and finite extensions of its residue field​
For the record, I know nothing about ramification groups (at least by that name), so I can't help you there.
Indeed the correspondence you're talking about is true.
Now, forget about ramification groups: In a first step, I only need to find a simple (or maybe more complicated) criterion for deciding whether the local field defined by x^p - a is ramified or not.
Artin-Shreier theory, in my opinion, is for no use here since I m starting with a polynomial over a 0 characteristic field.
Do you remember exactly how does the discriminant plays in this problem?
Ok, I found the solution in a book:
You have to look at the equation X^p - a = 0 mod P^(p*e/(p-1))
when P stands for the prime ideal of your field, p the characteristic and e the absolute ramification index:
It has a solution iff the extension is unramified.
In the case of a more general Kummer extension of degree p^n, n>1 the solution is much more complex and you can look at
http://www.springerlink.com/content/l54k280u0255l652/
for a solution.
Thanks for your help!
The point was to use Artin-Schreier on the residue field. But that's mainly because I know finite fields a lot better than padic fields. :smile:
np! I wish I could have done more.
