Drakkith said:
How so? The fusion of two protons in the Sun's core leads to the creation of deuterium. A neutrino and a positron are released to conserve charge and such.
Got a reference to this? It's not something I've heard before.
I got this link from one of the other posters on this thread. However, it is well worth looking at. Note that the electric charge is balanced not by emitting a positron (as both you and I had conjectured) but by electron capture. Thus, the initial conditions have three particles not two. The PEP reaction is not merely a two proton collision, as indicated in your question.
The PEP reaction is actually a three body collision. It could only take place under very high pressure.
It occurs to me that the PEP reaction could take place even at a low temperature if the pressure is high enough. After all, there is a mass defect between deuterium and protonium. Energy would be given off once the two protons are joined together as deuterium. According to quantum mechanics, the protons can tunnel over the potential energy given enough pressure. Tunneling doesn't require kinetic energy, just density. Even if the protons were not moving at all, a force slowly pushing them together could cause fusion.
I don't know if this is actually the case in the center of the sun. I defer to those who know nuclear physics a bit more. It may be that the average kinetic energy of the protons in the center of the sun is sufficient to cause fusion. However, the PEP reaction would definitely be speeded up by the high density of electrons and protons. So I don't know whether most of the fusion in the sun is caused by pressure, temperature, or whether it requires both at the same time.
Thermodynamics applies to any system close to equilibrium. It applies even to nuclear reactions. In order to apply thermodynamics, one has to know something about both the pressure and the temperature. I am sure that pressure and temperature are fairly well defined quantities in the center of the sun. To see what reactions are likely to take place in the sun, one has to discuss both the pressure and the temperature.
In the PEP reaction, a neutrino has to be given off to preserve lepton number. Therefore, there has to be some extra energy necessary to supply a neutrino. There is also a spin condition necessary to preserve angular momentum. All these conditions raise the threshold of energy for this reaction to take place.
Also note that I used the word catalysis wrong. The electron is absolutely necessary for the reaction to take place. It doesn't merely speed up a reaction that would occur anyway at a slower rate.
http://en.wikipedia.org/wiki/Proton–proton_chain_reaction#The_pep_reaction
“The pep reaction
Proton–proton and electron-capture chain reactions in a star.
Deuterium can also be produced by the rare pep (proton–electron–proton) reaction (electron capture)”
I am not sure that there isn't a nuclear catalyst in the sun that speeds up the fusion of deuterium. I thought the carbon nucleus with six neutrons speeds up some of these reactions. There are other isotopes in the sun that speed up or slow down some nuclear reactions.
Regardless, the PEP reaction does not start with only two protons. It requires an electron to be present, too. Obviously, the PEP reaction can't occur unless the density of electrons is very big. I don't think TOKAMACK creates the conditions of a PEP reaction, even nearly.
I should of realized that the reaction in the sun involved electron capture, not positron emission. I think that I read about positron emission in one of Gamow's books. In any case, I should have checked.
Le' Chateliers principle applies to nuclear reactions as well as chemical reactions. Since the plasma in the center of the sun is under high pressure. The favored reactions are those that relieve this high pressure. Emitting a positron would only increase the pressure. Absorbing an electron would decrease the pressure. Therefore, electron capture is the more likely process. So PEP would be the more likely process under conditions of high electron pressure.
Drakkith said:
Some of your conditions seem to be simple products of the reaction, such as the production of a neutrino and positron, not a condition for it to happen. As for conservation of momentum, that is taken care of by simply having two protons. Remember, we can view the collision as both protons having equal kinetic energy with respect to each other.
I did say that the two protons have to have enough energy to produce all particles necessary to satisfy all conservation laws. So the conservation laws do require some initial conditions to be satisfied.
Your argument is correct with regards to linear momentum. However, there is one caveat when you include angular momentum.
You are right, if you are talking about any state of the deuterium nucleus. However, the ground state of the deuterium nucleus has zero angular momentum. The deuterium nucleus in its center of mass frame has zero angular momentum. An off center collision of the two protons has an initial system with a nonzero angular momentum. Therefore, the result of a two proton collision that is off center has be an excited deuterium nucleus.
There is a limit to how much angular momentum one can put into a deuterium nucleus. At some threshold of angular momentum, the deuterium nucleus can't even form. So for very high relative velocities in an extremely off center collision, the deuterium can't form unless there is another particle around to carry off the angular momentum.
I have to thank both you and the posters who answered you. I didn't know about the PEP reaction before.
