Can someone elp me with a couple of homework questions im having trouble with
  • Thread starter Thread starter inflames829
    Couple Homework
A hunter needs to determine the angle to aim a gun at a target 54.08m away, with the bullet traveling at 143.91 m/s. Initial attempts to calculate the angle used incorrect equations and assumptions about projectile motion. Key discussions highlighted the importance of separating horizontal and vertical motion and using appropriate kinematic equations. After clarifying the correct approach, the hunter successfully found the right angle to aim the gun. The conversation emphasized the need for accurate calculations and understanding of projectile motion principles.
inflames829
A hunter aims directly at a target (on the same level) 54.08m away. If the bullet leaves the gun at a speed of 143.91 m/s then at what angle should the gun be aimed in order to hit the target? (answer in radians)
Vx = Vcos theta, Vx/V cos-1 = theta
im pretty sure this is not the right way to do it but i just don't know how to start or what equations to use
Involves projectile motion.
so I used this equation to y=v^2y0-v2y/2g. I rearanged it using the values i had to work out vy0, which i got 32.56, i used the distance as y and v2y as 0. Then i put that into this equation vy0=v0sin theta, to work out theta. I rearranged it to vy0/v0 sin-1 = theta, i used my value for vy0 and for v0 i used the velocity and got the answer 0.23. I then changed that to radians and got the answer 3.98E-3. But that is the wrong answer...What have I done wrong??
Which equation is this? It does not appear to have the right dimensions. (The term on the left has units of length; the first term on the right has dimensions length^3/time^2.)
I don't think you have enough information to find v_{0y} yet. Once we find the angle \theta that this problem is asking for, then you'll have v_{0y}=v_0 \sin\theta (if \theta) is the angle from the horizontal).
You have to keep track of motion separately in the horizontal (x) and vertical (y) direction.
In this problem, what is the displacement in the horizontal direction \Delta x? in the vertical direction \Delta y?
Once you have those, you may have a formula that your book derived for this special case. If so, you can calculate the angle with just that one formula.
(If you don't have this special case formula, then you can solve the problem directly using the kinematic equations for the x and y directions.)
i found this equation. R= v^2 sin 2 theta/g. If i put my values in there i get 2.23 x 10 ^4, the right answer is 1.28 x 10^-2. I am pretty sure this equation is the correct one, can you please give me hints on what I've done wrong?
Hi inflames829,
Yes, that is the correct question. (It is derived by setting \Delta y=0 for projectile motion with no air resistance, and so applies when that is true y_f=y_i.)
However, the answer you got is huge! The problem is asking for an angle to aim a gun, so it's looking for an answer whose magnitude is less than \pi/2 or about 1.6 or so (in radians). Did you solve your equation for theta? If so, please post what you actually put into the calculator.
ive got the right answer now. I realize what i did wrong. Thanks for the help though
15K
