How Do I Rearrange I=K(cosØ)ⁿ Using Logarithms for Linearization?
  • Thread starter Thread starter MrW
To rearrange the formula I = K(cosØ)ⁿ into a linear format using logarithms, take the logarithm of both sides to obtain log I = log K + n log(cosØ). By defining Y = log I, X = log(cosØ), and C = log K, the equation can be expressed as Y = C + nX, which resembles the linear equation format y = mx + c. This transformation allows for the plotting of data, with n and K as constants, to create a straight line graph. Understanding this process is essential for statistical data analysis involving the original equation.
MrW
Hi
i need to rearrange this formula
I=K(cosØ)ⁿ
in to linear format ( y=mx+c , y=mx)
and i need to use logs to do so which i have no idea about.
I understand the very basics of logs, even if someone could just give me a few clues how to work it out that would be great
can anyone help, will be v grateful
thanks
there is no "linear format" for the cos function. You could use taylor expansions to derive its series, but that's about it.
MrW,
are u working on some statistical data?
I = K (cos(phi))^n
Taking log on both sides,
log I = log K + nlog(cos(phi))
If u put Y = log I , X = log(cos(phi)) and C = log K,
the equation becomes,
Y = C +nX
-- AI
Hi
yes i am, thanks for your help. What you have said looks right ( as far as i know but i will need to look over it to get the undertanding.
I need to bascially put some data ( n and k are constants) into a graph which once rearranged should be a straight line.
thanks again
