Can someone me start this problem?
  • Thread starter Thread starter courtneywetts
To estimate the average R value for a house in Connecticut, given the average January temperature of 25.1°F and an oil usage of 200 gallons for a 2600 square foot home, one must first identify the appropriate formula for calculating R values. The discussion emphasizes the importance of showing work or attempts at solving the problem to receive assistance. Participants suggest researching the relevant equations and procedures needed for the calculation. Engaging with the problem-solving process is crucial for effective help. Understanding the relationship between energy loss and R value is essential for finding a solution.
courtneywetts
The average temperature in Connecticut in January is 25.1 F. An average home uses 200 gallons of oil. The surface area is 2600 square feet. Assuming that all the energy content of your heating fuel escaped through the house walls and roof, estimate the average R value for the house.
You must show some work or some kind of attempt at solving your problem before you can get help from the PF.
I would suggest you find out what formula or procedure to use to calculate R values.
