Can someone please explain this simple harmonic motion equation for me?
The discussion focuses on understanding the simple harmonic motion (SHM) equation, particularly the meaning of its components. The variable "x" represents the displacement from the equilibrium position of a spring, while "F" denotes the force exerted by the spring, following Hooke's Law. The equation illustrates that the acceleration (second derivative of position) is proportional to the displacement, with the constant "k" indicating the spring's stiffness. The negative sign in the equation signifies that the force acts in the opposite direction of the displacement. A clear grasp of these concepts is essential for comprehending SHM dynamics.
nukeman
This is not a homework question, as we just started getting into SHM, and I want to be 100% clear what this equation means.
Can someone please all the parts, or have a site that really explains this formula?
Do you know what x is?
Do you know what is meant by dx/dt ?
Do you know what is meant by dv/dt ?
No not really. I am looking for a clear explanation of what these all mean.
Thanks!
Is x the x = 0 equilibrium position?
Yes.
You can think of that equation as an application of Newton's 2nd law for a force obeying Hooke's law.
The second derivative of position wrt time is the same as acceleration, so all this equation is saying is ma = -kx, which means that F = -kx, which is Hooke's Law. To understand what this means you first need to know what x is defined to be. It usually means displacement from the equilibrium position of the spring. Also, "F" usually means the force exerted by the spring. If we ignore the "-k" for a second, we see that the Force is proportional to displacement, which means the more the displacement of the mass, the larger the Force exerted by the spring. The "k" is the constant of proportionality and the minus sign indicates that the direction of the force is opposite to that of the displacement (i.e if you pull the mass to the right, the spring tends to pull it back to the left, which makes sense intuitively).
