Can someone show me how this would turn out
  • Thread starter Thread starter thomas49th
The discussion centers on calculating the square root of (3 1/3) and determining if the result is rational or irrational. The expression simplifies to (10/3)^{1/2}, which is approximately 2.108185. It is suggested that this number is irrational because it does not represent the ratio of two perfect squares. Participants note that calculators can only provide approximations, making it difficult to definitively classify the number as rational or irrational. The conclusion emphasizes that if a rational number is not the ratio of two perfect squares, its square root is typically irrational.
thomas49th
What would this number be?
(3\frac{1}{3})^{\frac{1}{2}}
Is it rational or irational?
How do you work it out?
\frac{10}{3}^\frac{1}{2}
Your answer should be \left(\frac{10}{3}\right)^{\frac{1}{2}}
Do you think it is rational or irrational?
I THINK it's irrational, because it look ugly. Isn't it 2\sqrt{\frac{10}{3}}
As you put the denominator as the surd outside thingy (wot ever it's called) and the rest inside the root. On a calculator it gives me 2.108185... which is a real number, and virtually all real numbers are irrational?
P.S How do i tell on a calculator if the number is real or not. It could stop after 50 places, and my calculator only goes to 11
You can't. ALL numbers a calculator deals with are rational and so, in general, only approximately the number you want.
In general, if a rational number is not the ratio of two perfect squares, i.e. m2/n2, then its square root is not rational.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
