Can voltage and current values be captured and logged in labview?
  • Thread starter Thread starter atlbraves49
    Current Voltage
Current voltage and current measurements in LabVIEW can be automated by using data acquisition modules, particularly those from National Instruments. These USB-based modules are user-friendly and integrate seamlessly with LabVIEW as drag-and-drop objects. For accurate current measurements, a low-value shunt resistor is recommended to facilitate differential voltage measurement. This setup allows for simultaneous logging of temperature, voltage, and current data. Implementing these solutions will enhance the efficiency of data collection in the described thermoelectric module system.
atlbraves49
I'll describe our current set up:
http://img152.imageshack.us/img152/195/simplepicturegv9.th.jpg
We have energy being drawn from a thermoelectric module, to a resistor (just dumping it). We are acquiring the temperatures across the thermoelectric module, into labview, using thermocouples, but right now, current and voltage measurements are being done manually (using a voltmeter). Is there a product that allows you to acquire current/voltage data and send it to labview? Anything you can recommend for this current set up?
Check out the data aquisition modules from companies like National Instruments. Their USB-based data acq modules are especially handy. For current acquisition, you'll probably need to put in a shunt (low value) resistor, and do a differential voltage measurement across the shunt.
BTW, most of NI's data acq modules are built into LabView as drag-and-drop objects, IIRC.
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
