What Is the True Speed of Earth in Relation to the Solar System?
  • Thread starter Thread starter hafiz ns
    Earth Speed
Determining Earth's speed in relation to the solar system is complex due to the lack of a stable reference frame. The Earth moves at approximately 1670 km/hr, while the solar system travels at about 828,000 km/hr, with the galaxy moving at 130 km/sec. To calculate Earth's total speed, one must consider all these velocities, but the challenge lies in the unknown motion of the galaxy within the universe. The cosmic microwave background (CMB) provides a useful reference frame, revealing that Earth moves at 370 km/sec relative to this ancient light. Ultimately, speed is relative and requires a defined reference point for meaningful interpretation.
hafiz ns
we cannot find Earth speed..,.,.,.,,.
to find speed of an object we want a stable surface.
lets go through an example:-
if a train in moving with a speed of 100 km/hr and a car is in top of the train moving with a speed of 50 km/hr (in same direction). then the speed of car is 150 km/hr.
In this situation let's take the car as Earth and the train as solar system.
the Earth is moving with a speed of 1670 km/hr and the solar system is moving with a speed of 828000 km/hr . the solar system is in galaxy moving with a speed of 130 km/sec.
hence to find the speed of Earth we have to add these all matters:-
just like:-
1670+828000+and the speed of galaxy = speed of earth
till this time we don't know that the galaxy is inside any stuff. if yes we don't know the speed of that stuff
so we can't find the speed of earth
iam confused please replay fast.,.,.,
Astronomy news on Phys.org
A velocity of its own does not mean anything so you cannot say that the velocity of an object is a particular number. You can only define relative velocities, ie, how fast things move relative to each other. This is true for all objects.
but does it have any possibility ?
No, because as I just told you, the question has no meaning.
... we don't know that the galaxy is inside any stuff.
so we can't find the speed of Earth
To expand on what Orodruin said: for specific applications we can give the speed of the solar system (for example) a useful meaning, by CHOOSING a background or frame of reference.
One of the most useful reference frames is that of the cosmic microwave background CMB. We are surrounded by a kind of "soup" of ancient light---the most ancient light we can detect.
It is essentially all the same temperature, as long as we adjust for the Earth and solar system moving thru it. We are moving at 370 km/second in a certain direction thru this light. The doppler effect of our motion causes there to be a "hot spot" in the sky in the direction we are going.
Because we are running into the light and that makes us see the light in that direction with a little more energy---about one tenth of one percent warmer.
If we cancel out the doppler effect of our own motion relative to CMB, that is remove that hot spot (and the doppler cold spot in the opposite direction) from the data, then the CMB appears essentially the same temperature in all directions. With just some tiny fluctuations.
The CMB is the leftover glow from the ancient matter of the universe---the original hot gas as it was at the time when it had become just cool enough to be transparent, so that its light could go free without being scattered and could come down to us. (with its wavelengths stretched out by expansion but otherwise mostly unchanged) We SEE the ancient matter by this ancient CMB light and we see our motion relative to this ancient matter by the doppler effect of moving 370 km/s relative to it.
If you want to talk about motion and speed of motion you have to first give it a meaning by saying what the motion is relative to.
Likes Monsterboy
Gotta correct misconceptions.
Start from one minute or just watch the whole thing for more stuff.
Though small but we must get our facts correct.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
