Cancellation of areas integral
In summary, the cancellation of areas integral is a mathematical concept used to find the difference between two integrals, with one being the inverse of the other. It is commonly used to evaluate the area between two curves or functions and has various real-world applications, such as calculating displacement, profit/loss, and work done. The formula for calculating it is ∫(f(x) - g(x)) dx, and the key steps involve identifying the functions, finding their inverses, setting up the integral, evaluating and subtracting the values. Some common mistakes to avoid include not considering limits, incorrect substitutions, and not simplifying the integrals.
chjopl
Give an example of an integral on (-infinity, infinity) that will lead to an ambigious answer if we evaluate the interal in terms of cancellation of areas.
Hmmm, sounds like you want a function that is NOT integrable from 0 to infinity and is an odd function. ( f(x)= x leaps to mind.) Do you see WHY that leads to an "ambiguous answer"?
The cancellation of areas is a concept in mathematics that refers to the cancellation of positive and negative areas in an integral, resulting in an ambiguous answer. This can occur when the function being integrated has both positive and negative values over the interval of integration.
For example, let us consider the integral of the function f(x) = x^2 on the interval (-infinity, infinity). This integral can be evaluated using the fundamental theorem of calculus as follows:
∫_-∞^∞ x^2 dx = [(x^3)/3]_-∞^∞ = ∞ - (-∞) = ∞ + ∞
Here, we can see that the positive and negative areas cancel out, resulting in an ambiguous answer of infinity plus infinity. This is because the function f(x) = x^2 has both positive and negative values over the entire real line, leading to the cancellation of areas.
In situations like this, it is important to carefully consider the properties of the function being integrated and the limits of integration to avoid the cancellation of areas. In this case, we could avoid the ambiguity by breaking up the integral into two separate integrals over the intervals (-∞, 0) and (0, ∞), where the function has only positive or negative values respectively.
In conclusion, the cancellation of areas can lead to an ambiguous answer when evaluating integrals. It is crucial to be aware of this concept and carefully consider the properties of the function and limits of integration to avoid any potential ambiguities.
What is the concept of cancellation of areas integral?
The cancellation of areas integral is a mathematical concept that involves finding the difference between two integrals, where one is the inverse of the other. It is used to evaluate the area between two curves or functions.
What is the formula for calculating the cancellation of areas integral?
The formula for calculating the cancellation of areas integral is ∫(f(x) - g(x)) dx, where f(x) and g(x) are the two functions or curves being integrated.
What is the significance of cancellation of areas integral in real-world applications?
The cancellation of areas integral has various real-world applications, such as calculating the net displacement of an object from its velocity function, finding the total profit or loss in economics, and determining the work done by a variable force in physics.
What are the key steps involved in solving a cancellation of areas integral?
The key steps involved in solving a cancellation of areas integral include identifying the two functions or curves, finding their inverse functions, setting up the integral, evaluating the integrals, and finally finding the difference between the two evaluated values.
What are some common mistakes to avoid when solving a cancellation of areas integral?
Some common mistakes to avoid when solving a cancellation of areas integral include forgetting to take into account the limits of integration, making incorrect substitutions, and not simplifying the integrals before evaluating them.
  • Calculus
