Capacitance of a cylindrical capacitor
The discussion focuses on calculating the capacitance per meter of a coaxial cable with specified inner and outer radii, filled with polystyrene. The formula used for the calculation is C = (2 * π * E * K) / ln(b/a), where K is the dielectric constant. An initial attempt yielded a result of 551.05 pF/m, which was incorrect. After further review, the correct capacitance was determined to be 98.596 pF/m, highlighting the importance of careful calculations. The thread emphasizes the need for accuracy in using formulas and calculators in physics problems.
stosw
A coaxial cable used in a transmission line has an inner radius of 0.15 mm and an outer radius of 0.65 mm. Calculate the capacitance per meter for the cable. Assume that the space between the conductors is filled with polystyrene. (Also assume that the outer conductor is infinitesimally thin).
C=\frac{2*pi*E*K}{ln(b/a)}
After converting mm to m and plugging in values (used K = 2.6 for capacitance per meter) I got 551.05 pF/m.
Webassign has told me this is incorrect. Could someone point me where I went wrong?
I get a completely different answer when I plug the numbers in. Try showing your work here so we can see where your error is.
Thanks.
Guess I should be more careful when using a calculator.
Correct answer is 98.596 pF/m
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
