Capacitance Variations in Cylindrical Capacitors
Capacitance variations in cylindrical capacitors, specifically in Fuel Gauging Tubes (FGT), are influenced by factors such as concentricity, straightness, and circularity of the tubes, as well as the permittivity of the dielectric material. The observed variations exceed the acceptable limit of plus or minus 0.2 picofarads, prompting an investigation into potential causes, including temperature fluctuations and mechanical vibrations. The capacitance formula indicates that eccentricity and the proximity of the inner and outer tubes can significantly affect measurements. Calibration is not feasible due to strict specifications, necessitating a focus on improving manufacturing consistency and addressing geometric discrepancies. The coaxial design is typically robust against alignment issues, suggesting that further analysis of the fabrication process may be required to meet performance standards.
mparvin
The capacitance measurements of “Fuel Gauging Tubes” (FGT) that are composed of carbon composite inner and outer tubes shows unacceptable level of variations and I need to reduce the variation of capacitance.
I would like to know what are the contributing factors to capacitance variations. I am aware of the effect of concentricity, straightness, and circularity of tubes. There is a clamp shape connector mounted over the outer tube that attaches a wire to it by using conductive adhesive. A wire is also glued to the inner tube by the same type of adhesive.
The probe assemblies are located in the aircraft fuel tanks and are utilized to sense the fuel height and density. The probe assemblies are linear coaxial plate cylindrical capacitors, utilizing identical plate spacing. The probes are electrically stimulated by AC signal.
Mike
The main variables would be spacings and the permittivity of the material between the plates. Can you correlate some of the variations with variation in temperature? Are these variations with just one sensor over time, or between many sensors that you receive for production runs? If it's unit-to-unit variation, just calibrate them at the factory. If it's temperature variation, add a temperature sensor and do temperature compensation for the measurements. If it's vibration, make them more robust mechanically, or use a reference unit in a dry spot to subtract out the mechanical variations...
Do you have a web link to a typical one of these devices?
The measurements are done on identical units at room temperature in a static situation and the dielectric between the tubes is air. Calibration is not an option. We have to meet a spec. that calls for limited range of capacitance variations.
I don't have a device uploaded yet.
What do the curves look like for the two units for capacitance versus fluid level? Do they have the same slopes, but different starting values? Or are their slopes different too? If (a), then you can add capacitive ballast to overlay the two curves. If (b), then there is a geometry inconsistency between them. Have you been able to make careful measurements of the geometries of these two units, and compare those to calculations of what those differences would do to the capacitance vs. fluid level curves?
Also, are these devices that you are fabricating yourselves, or do you buy them from somebody? If you buy them, what do their spec. sheets say about the tolerances and variations? Are you trying to figure out how to help the manufacturer improve the product so that you can meet your overall system spec?
And why can't you use calibration to fix this? It's a very common technique in sensor circuit design, as long as you know what variables affect the accuracy of the sensor.
It seems that I have failed to give a clear explanation about my problem I try again:
The observed variation of capacitance is not related to actual application of the device. It is observed during testing and measuring the dry capacitance. The measurements must fall within plus or minus 0.2 pf to be acceptable. We are getting a much large variation and trying to find out the source of it.
Based on the formulation of capacitance: c = 2pi * epsilon*L / log (ri/ro), having assumed that the dielectric of air is constant, the determining factors are length L and radius of tubes. In the formula, it is assumed that the two cylinders are concentric. I would like to know if eccentricity is a contributing factor. To exaggerate the situation, what would happen when the inner tube is very close to the outer tube? In this case, there will be varying distance between the two substrates. How would the capacitance of this off center capacitance compare with a concentric situation? The diameter of the out tube is about 1 inch and inner tube diameter is 0.6 inch. The length is 6 inches.
mparvin said:
(snip). The measurements must fall within plus or minus 0.2 pf (snip)
You are using a "jig?" Handling the devices with automated equipment? (Or, at least using gloves?)
0.2 pf change? You get that by moving test leads. Double shielding might help on the instrumentation end. You've still got the problem of locating the capacitor relative to ground in your measurement fixture.
Bad assumption
The coaxial geometry is selected for standard capacitors, construction of dielectric cells, level probes, and the like for its insensitivity to misalignment of axes.
You might want to hunt down a copy of Oliver & Cage if this is going to be a long term measurement program.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
