Capacitor for high current discharge
The discussion revolves around using a solar panel with low current output (5 volts, 100mA) to charge a battery, with the idea of incorporating a capacitor to store energy for high current discharge. Concerns are raised about the minimum current required for lithium-ion batteries and the implications of using a rectifier, which could prevent charging if the voltage is insufficient. The user has connected multiple solar panels to achieve a higher voltage and is experimenting with a capacitor to stabilize output, especially under cloudy conditions. However, issues arise with the phone discharging instead of charging, prompting questions about the circuit design and safety of using lithium batteries. Recommendations suggest using NiMH batteries instead for safety and efficiency.
ramonegumpert
Dear Experts
i have a solar panel but the current is not high enough .
I have about 5 volts to charge giving about max 100mA (specs).
I am thinking of using a Capacitor to store all the low currents such that when the capacitor is fully charged, I need a circuit to discharge all the high current in the capacitor to the battery.
I am not sure if this is the same as hooking up the panel to the battery without capacitors.
I also not sure is there a minimum current (at 5 volts) the lithium ion battery would accept current? Am I right to say any small amount of current will charge the battery at the right voltage and the only difference is how long it takes to charge?
By the way, I will add a rectifier to maintain a steady voltage.
But does this not mean that if voltage is not sufficient, there is no charging at all vis-a-vis without a recitifier ?
Eg. If I use a 7 volt rated solar panel, connecting to a rectifier taking about 2 volts, the remaining 5 volts will charge the battery. But if the sun is not strong enough, producing only 6 volts or less, the rectifier may not have 5 volts output . What happens? No charging?
Thank you for reading my question.
Have a nice day.
Best regards
Pascal
It usually is no different.
Li-I batteries are very fastidious and fussy, and are not safe to experiment with. They are easily damaged and can catch fire if conditions are not to their liking. https://www.physicsforums.com/images/icons/icon9.gif Can you use NiMH cells instead?
By the way, I will add a [strike]rectifier[/color][/strike] regulator[/color] to maintain a steady voltage.
If the voltage is lower than the regulator needs, then there will be no charging.
A 7v panel delivering 100mA should be about right for 5 x NiMH cells, each 1.2v. Place a current meter in series to verify that charging is proceeding okay. No regulator required. :smile:
Uh ... I thought solar cells produced DC voltage, no? You have one that produces AC voltage?
Dear NascentOxygen and Phinds
Sorry, my bad, I incorrectly used the word 'rectifier' for regulator.
NascentOxygen has given me great advice. I really appreciate your kind help.
By the way, I could not find a 7V solar panel at 100mA. The store only has 6V at 100mA.
So, I bought another 4 x 5v panels rated at 100mA and connected them as 10v pairs.
Because of the potential difference, I drop the voltage down using a regulator at 5.5v and connected a 1 farad capacitor at 5.5v before regulator whose output goes to charge the battery.
Based on the voltmeter, it seems that adding a cap stabilized the voltages a bit especially when the sky is cloudy. Is this observation making sense?
If I add a same cap after the regulator, would that make it even more stable? But what happens when the sky is too cloudy? would that not make the capacitor discharge to the solar panel? So, I added a small zener diode to block the discharge.
Still my phone, which has a larger lithium battery than iphone, is DIScharging rather than charging my phone.
That is why I wondered is it due to the position I placed the diode ? I could not understand why the phone is not being charged. For example, after 5 minutes, the charged % actually dropped rather than increased.
Best regards
Pascal
I didn't suggest you would. It was you who nominated that figure of 7V. :smile:
The store only has 6V at 100mA. So, I bought another 4 x 5v panels rated at 100mA and connected them as 10v pairs. Because of the potential difference, I drop the voltage down using a regulator at 5.5v and connected a 1 farad capacitor at 5.5v before regulator whose output goes to charge the battery.
One farad?!
It should make no difference, unless the regulator is not stable and is oscillating or something. Maybe you are using a switching regulator? What is the type number on the IC?
Data sheets for some regulators may specify where you can add a small capacitor to give it greater stability.
Capacitors draw practically no steady current, so you are not losing any power in the capacitor. Your inclusion of a zener diode is wrong. Zeners conduct in both directions, it can not help you. Leave it out. Possibly your battery may discharge into the regulator when the panels are producing no voltage; can you put a current meter in series there to measure any current in the wrong direction?
You are using the solar panel to charge a lithium cell? As I indicated, lithium cells are dangerous and are not sold for experimenters. I recommend that you charge only NiMH cells from your homebrew solar charger. You could charge 6 or 7 NiMH cells from your 10V panels and as NiMH cells are tolerant and relatively safe, there would be no need for a wasteful regulator. There may be a safer way to charge Li cells from the fully-charged NiMH cells.
A switching regulator could be very efficient and you could charge a lower voltage battery than your solar cell without losing appreciable energy. The regulator could be made 'intelligent' so that it charged your battery as fast as possible, too.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
