Capacitor (the dissipation of electrical energy)
In an L-R-C series circuit with specific values for inductance, resistance, and capacitance, the average power dissipated in the resistor is 48.2W. The phase angle is 0.776 radians, and the power factor is 0.714, indicating the relationship between real and reactive power. The impedance is calculated at 329 ohms, with an rms voltage of 149V and an rms current of 0.453A. It is clarified that the average rate of electrical energy dissipation in both the capacitor and the inductor is zero, as these components store energy rather than dissipate it. This scenario exemplifies a common trick question in electronics exams regarding energy dissipation in reactive components.
jazzylady03
An L-R-C series circuit with an inductance of 0.116 , a resistance of 235 , and a capacitance of 7.25 carries an rms current of 0.453 with a frequency of 393 .
The phase angle is .776radians.
The power factor is .714
The impedance is 329ohms
The rms voltage is 149V
The average power is 48.2
The average rate at which electrical energy is converted to thermal energy in the resistor is 48.2W.
I need to figure out what the average rate at which electrical energy is dissipated (converted to other forms) in the capacitor?
and What is the average rate at which electrical energy is dissipated (converted to other forms) in the inductor?
Any help is GREAT!
The answer is 0 for both parts
This is an example of a common "trick" question that I've encountered on some electronics exams (like the one I took back in 1970 for my FCC license)...they give you voltages, frequency, component values, etc, then ask for the power dissipated in a capacitor (or inductor). The answer is simple: ZERO. Reactance stores energy, but does not dissipate it.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
