Question about this Capacitor voltage integral equation
The discussion focuses on deriving the capacitor voltage equation from the integral of current. The original equation, v(t) = 1/C ∫t-∞ i(τ) dτ, is transformed by recognizing that the initial voltage v(t0) represents the history of current flow. By splitting the integral into two parts, the relationship v(t) = v(t0) + 1/C ∫tt0 i(τ) dτ is established. This shows how the voltage at time t depends on both the initial condition and the current flowing from t0 to t. The explanation clarifies the connection between past current and present voltage in circuit analysis.
JMFernandez
Hi.
I don´t know if this question should be in the maths forum, but as it´s related with circuit analysis, I will post it here. I just would like to know how you get:
v(t) = 1/C ∫tt0 i(τ) dτ + v(t0)
v(t)=1/C ∫t-∞ i(τ) dτ
I just know the basics of calculus and I don´t know how to operate the second equation to get the first one.
Thank you in advance.
JMFernandez said:
Hi.
The equation describes how the cap voltage changes as current flows through it. Fortunately, all of the history of past current flow(s) is represented by the voltage at any time. That is what the initial voltage ##v(t_o)## is. Since that doesn't depend on the variable ##t##, we can just call it a constant value, the "initial condition" of the capacitor. So,
$$v(t) = \frac{1}{C} \int_{-∞}^{t} i(\tau) \, d\tau = \frac{1}{C} \int_{-∞}^{t_o} i(\tau) \, d\tau + \frac{1}{C} \int_{t_o}^{t} i(\tau) \, d\tau \equiv v(t_o) + \frac{1}{C} \int_{t_o}^{t} i(\tau) \, d\tau$$
Thank you. Very clear and concise explanation!!
:smile::smile:
Likes berkeman and DaveE
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
