Capacitors and regenerative braking
35 replies · 8K views · last reply
RedBaron
So I'm interested in adding a bank of capacitors to help reduce the initial load on my batteries when accelerating from a stop but my current set up uses regenerative braking. My electrinics are this order, Motors, VESC, BMS, 10s5p Li-ion pack. If I add capacitors between the bms and vesc to supply the initial burst of energy needed for take off would regenerative breaking cause an over charging issue if let's say braking down a long hill? Or would the extra power flow back to the battery once the caps are full? Just trying to understand a little more, thanks for any help.
You already HAVE regenerative braking. Why do you think adding additional storage will matter? Do you think your current storage is insufficient?
Welcome to the PF. :smile:
Can you post a schematic of your system? It sounds like it should be okay, but there are some potential issues that it would be good to check. Also post links to the datasheets for all of the components please (batteries, caps, motors, etc.). Thanks.
The motors are 2x 170kv 65amp each, the Vesc (motor controller) is a 200amp 10s. The bms is a 120amp continuous discharge, and the battery is an 18ah and capable of 150amp continuous discharge. I don't need or want my motors maxed out so I chose 50amps each bringing my total power required to 100amps continuous at any given time. I chose components that gave me head room for thermal efficiency and redundancy. Have I reached maximum efficiency because my battery can push 150a and I'm only asking for 100a? Would adding caps help reduce strain on the battery? I've ran out of room to add any more batteries so I was wondering if a few good caps could help.
Also I don't have a good way of providing a schematic. But I'll work on it.
If you can find a PDF or JPEG file, use the UPLOAD button in the lower right of the Edit window to attach a file. Otherwise, you can post a link to the documents if you have a URL. :smile:
RedBaron said:
2x 170kv
where are you getting 170,000 V from ?
kV in this context means that the motor gives 1000 rpm per every volt supplied (170 kV is a beast).
It is about as obvious as charging 2.2 Ah battery with 2C current (which means 4.4 A - C stands for battery capacity without the "h" part).
Ah, the joys of mixing meanings and symbols from different trades/hobbies :smile:
Lol, sorry for not being very specific. I'm super new to this so I'm doing my best to use the proper terms. Borek is correct. I'm almost done with a digital version of the schematic for you guys. Thanks for helping. This is my first project and I just felt compelled to make my own personal Mobility device. It's so exciting that the tech has gotten small enough to do this stuff.
thanks mate ... a totally new way of describing kV for me :smile:
edit ... so my next Q is ...
is this even a valid/practical value for what the OP wants to achieve ?
A sketch with a sharp pencil and a photo is usually possible. Not the best but it can carry the message.
I would imagine that a super capacitor would dump current better than any battery (one of their claimed advantages). The Power that is dissipated by brakes can be much higher than what a motor / engine can supply and a capacitor could probably cope better than a battery (Edit - assuming the motor can!). However, to implement this would require some clever design because of the Voltage/Charge relationship in a Capacitor. There would be little point in just connecting battery and capacitor in parallel.
Both the batteries and caps would be in parallel right? Battery voltages do not change much between states of charge, for Li ion off the top of my head full discharge is ~2.8V/cell, max charge is 4.2V/cell but since you are probably not trying to kill your batteries you probably won't go discharging into the 0-20% SOC range, so basically your cell voltage changes by about 0.8-1.2V from "full" to empty. So then you would take your max cell change in voltage, multiply by number of cells, and you'll get the range of voltage operation for your caps. You have 10 cells in series, so your bat volts will vary from 30V to 42V. Since the batteries determine this min and max voltage to avoid damage, the energy available to use in your caps will be 1/2C(Vfull^2-Vempty^2), when you then go an math out the number of joules your batteries are delivering over that voltage and and you then work out if you want say 1/10th to come from the caps, the size of the capacitors needed will make you go and buy more batteries because you might have a shot at fitting those.
Even "super caps" are cute compared to the energy storage of electrochemical cells, and that is adorable when compared to the chemical potential energy of petrol.
Basically capacitors right next to your inverter will help reduce AC ripple current on the batteries (ie from the PWM) but it won't give you any significant energy storage for driving.
A 10Ahr 36V nominal battery stores ~1.3MJ, to have a capacitor that stores one tenth that (130kJ) over the same voltage range is about 300F, note the lack of micro in front of that F!
Oh and re power flowing to caps then battery, that's not how it works, power will flow into both at the same time, realistically the batteries will store a lot more energy than the caps as the voltage increases.
Why? Their charge / voltage characteristics couldn't be more different. How would the Capacitor's stored energy be significant if it is tied to the batteries? I can't think what the optimum way of connecting the two would be but in parallel would seems to be bad value - considering the cost of the capacitor bank.
Well I can' think of any other way you would run both batteries and capacitor energy storage together to feed the same DC bus for a motor drive. I mean you could link the caps with bi directional DC-DC to allow you to use the full voltage range of the cap, but that's likely more complicated than its worth.
I was just answering the OP question by showing how huge the cap bank would have to be even be noticeable, hence demonstrating that it doesn't make sense!
I think that, to justify the cost of a big bank of expensive capacitors, they would need to be used by an intelligent circuit. I would imagine a switch mode 'charge router' to send the charge to the Capacitor when the motor volts go higher than needed for battery charging and to use that charge first, to run the motor. Endless fun, trying to get it right, of course but you really have to do something to make the two storage devices compatible. I could be wrong but I think it would be very lucky indeed to find that a parallel connection was worth the money.
From what I've seen mixing storage is not done. You obviously have capacitors on a system with batteries (inside the inverter or DC-DC to supply the HF AC current needed to PWM) but for bulk storage I've only ever seen super caps or batteries. Super caps actually more in heavy duty applications where the vehicle has to stop and go a lot (eg garbage trucks, delivery trucks, busses) they get filled on a single deceleration, then provide the ooomf to get the vehicle back to 20-30 before the diesels take over again but no actual real storage. For hybrids they just can't match the storage density of electro chemical and honestly modern Li ions almost behave as a capacitor, the source impedance numbers are quite good.
As I recall there were some electric powered busses in Singapore (?) that use supercaps in combination with other batteries. I'll try and find more info.
If the batteries are connected in parallel to capacitors, capacitors are basically all the time fully loaded from batteries, aren't they? How are they going to absorb any energy then? There is a bit of margin as the voltage drops under the load, but I still don't see how it is going to be in any way efficient without some kind of additional circuitry (basically I am saying the same thing @sophiecentaur said).
Yes, to use the super-caps efficiently, a separate converter is needed. As you say, this adds complexity, and the apparent positives of super-caps fades away pretty fast when all the realities are factored in. Both the size/cost and complexity. But there are some applications where they make a lot of sense, and costs an capabilities are improving.
Do you have a way of measuring/logging your DC current draw? Like do you literally never exceed 100A from the battery ever during use or are there maybe short bursts (few sec) of a 4-5 hundred amps or more during accel or regen? 100A from 10s pack is only ~4kW, which is not much.
From my calculations, based on the "regen" part of thread title, I'd say a nominal energy requirement for the capacitors would be about 4000 joules.
1/2 x 84 kg x (9.7 m/s)2 ≈ 4000 joules​
This assumes a CMS is installed. (Capacitor Maintenance System)
For a bicycle? According to this website, 750 watts is the maximum allowable.
4000 watts ≈ 5 hp
I was in total agreement with your statement until I ran across the following at wiki; "...hybrid drive of up to 200 kW input and output power using "superbatteries" made with batteries and supercapacitors connected in parallel..."
Of course, being wiki, I googled for more information, FOR HOURS, with little luck.
I'm guessing now, from my research, and what nearly everyone else in the thread has stated, that the system was a bit more complicated than just "batteries and supercapacitors connected in parallel".
I also checked their "KERS" page, and found; "Experimental Machinist Douglas Goncz connected three ultracapacitor packs on an electric hub equipped recumbent bicycle in series/parallel with a 4PDT toggle switch in 2007 and described the resulting MObile Experimental Physics Educational Demonstrator (MOEPED) and its 19 kJ "electric flywheel" in a newsgroup posting to the moderated newsgroup sci.physics.research dated 11/9 of that year titled "MOEPED Update" and in other newsgroup threads under the keyword "MOEPED". In parallel, the packs were a regenerative brake; in series, they were a boost source. The vehicle remained in use so equipped until 2010. It was surplus disposed in 2013."
I may have to contact Mr. Goncz directly, and see if he has a block diagram of the system, as I have no idea how to access "newsgroups" any longer.
I did find him on "Google Groups", but he has been a VERY prolific experimenter, since at least 1999, and it's just too much to wade through.
hmmm...
(google, google, google)
Ah ha! I think this may be the original post I was looking for.
I will have to search some more, and find out why he disposed of his bicycle in 2013.
4000 watts ≈ 5 hp
Where do you get 84kg, 9.7ms, or the bicycle part from? I read this thread 3 times just now, and I'm pretty sure did not see those mentioned?
84 kg = me and my bicycle (Empirical data!)
9.7 m/s came from some website and my maths: fast roadies: 9.7 m/s = 21.7 mph = 35 km/h (real worldish stuff)
"bicycle" was interpolated from the given data (guessing we're not talking about an automobile :rolleyes:)
The V/C characteristic of a Capacitor is a constant slope (the Capacitance. For a Lion battery, the drop in volts from near full to dying is pretty much a horizontal line. From full to usably empty, the battery volts only drop by around 10%. I can't see the similarity there.
I could imagine that, if weight is not a problem, with the battery fully charged, carrying some Capacitance could give you some advantage with acceleration for a short burst but, with the best will in the world, you can only get 10% of the charge in the Capacitor. But I don't see a problem with including some smart switching in a design that's obviously going to be a bit pricey in any case. (I'm only arguing against the simple idea of parallel connection.)
One point in favour of the SuperCapacitor is that the actual Energy capacity is all at the top of its voltage range ( Energy = (CV2/2) so you don't have to nearly discharge it. Any installation with SuperCs in it is going to have some fancy switching control in any case if the user is going to have any idea what the accelerator pedal will do for him.
Lots of great info everyone. I'm blown away by the responses and the amount of information.
My max amp draw is capped to 100A in the programming of the motor controller So there shouldn't be any bursts going on. I'm 155lbs. I was interested in adding super or regular caps because I do a lot of stop and starts on the route I'll be taking. Here is a super rough sketch of my set up. I would be adding a bank of caps inline with the leads going to the motor controller from the bmsP- and battery+. I have heard of people doing this but wasn't to sure how it works exactly or if it would be of any benefit even though my battery is theoretically capable of 150a sustained.
