Capacitors with different dielectric constants
Two capacitors with the same plate separation but different shapes (square and circular) can have the same capacitance due to differing dielectric materials. The square plates have a dielectric constant of ksquare = 3.4. To find the dielectric constant kcircular for the circular plates, one must apply the formula for capacitance, considering the geometric differences. The discussion emphasizes the importance of showing prior attempts and using the homework template for assistance. Understanding the relationship between capacitance and dielectric constants is crucial for solving this problem.
Clyner791
Two capacitors have the same plate separation, but one has square plates and the other has circular plates. The square plates are a length L on each side, and the diameter of the circular plate is L. The capacitors have the same capacitance because they contain different dielectric materials. The dielectric constant of the material between the square plates has a value of ksquare = 3.4. Calculate the dielectric constant kcircular of the material between the circular plates.
Hello Clyner791. Welcome to PF !
The following is a quote from the rules for posting in the Homework section of this Forum.
NOTE: You MUST show that you have attempted to answer your question in order to receive help. You MUST make use of the homework template, which automatically appears when a new topic is created in the homework help forums. Once your question or problem has been responded to, do not go back and delete (or edit) your original post.​
What have you tried?
Where are you stuck?
