Car Battery Amps: Understand & Calculate for Your Vehicle
Car batteries typically have a cold cranking amp (CCA) rating significantly higher than 45 amps, often around 350 to 650 CCA, which indicates their ability to deliver high current for short periods. The discussion clarifies that amp-hours (Ah) measure how long a battery can supply a certain current, with a 45 amp-hour battery theoretically providing 540 watts for one hour. Using a 100-watt light bulb connected to a 12-volt battery would draw approximately 8.3 amps, allowing for about 5.4 hours of operation if the battery were indeed rated at 45 amp-hours. However, the relationship between current draw and battery capacity is complex, as the battery's maximum output can exceed the continuous draw when starting a vehicle. Overall, understanding the differences between CCA and amp-hours is crucial for accurately assessing battery performance.
MountainDew
hello, i know car battery amps range from 40 amps to whatever, i just can't understand them, the amps aren't printed on the batteries and i don't know why? i have a pretty good ideal that my car battery maybe 45 amps, what does this mean? i know the alternator produces 55 amps, if i hooked a 100 watt light bulb up to my 45 amp car battery i know that the light bulb uses 100w/12v = 8.3 amps, so how do i figure how long the 45 amp battery will run a 8 amp bulb?:confused:
i was reading something on the web and was wondering if this could be right, knowing the battery is 45 amps, and i am using around an 8 amp bulb, i would assume 8 amps is how much the bulb uses per hour? if so, 8/45 = around 5.6 hours? could this be right?
i think you can do it this way to? take the 45 amps * 12v to get 540 watts, so we know the bulb is 100 watts, so i guess the bulb uses 100 watts per hour, which means it would last, estimating in my head, looking at the battery which is 540 watts, id say it would run little over 5 hours? does it sound like I'm on the right track?
Welcome to PF, Mountain. There must be a misunderstanding somewhere. If you have a 45 amp battery, you sure as hell aren't driving anywhere. The minimum cold cranking amps for a car battery is probably around 350. My Roadrunner draws 1,000 amps in sub-freezing temperatures.
Yes 45 amps sounds way too low. Automotive batteries supply much more current - the one I keep around the house is 650CCA (550 otherwise) but is slightly larger than what you would see in a car.
Anyway, some batteries will give a rating of the full charge in Amp-hours, usually in the form of "y amps for x minutes" written somewhere on the identification label. The product of the current supplied and the discharge time is relatively constant, so if you know how many amps your lightbulb will pull then you can guess roughly how long it will take to discharge the battery.
cold cranking amps are different from amp-hours which is what you want, cca is how many amps can be delivered short term during cold weather, amp-hours is how many amps can be continuously be delivered during one hour. so if you have 45 amps-hour then you get 540 watts that can be delivered continuous for an hour, the cca number will be higher, say 120 amps that can be delivered to the starter instantaneously during winter conditions.
my friend on msn is telling me that a car battery as way more than 45 amps, and I've seen it here, i apreciate all the help, but would you not agree that a 100 watt household bulb on a 12 volt battery would be using around 8.3 amps? and how long could i exspect this bulb to run? 5.4 hours? if so, would that prove the battery was 45 amps? I am sorry, i am fairly new to this and do understand i am lacking some knowledge
You're confusing the relationship between max output current (rate of change of charge / time) with the amount of charge (Q) the battery has. You can't get the max current (dQ/dt) the battery could ever output based on how long it took for the battery to discharge from loading it with a lightbulb that consumes such little power. The lightbulb will draw only so much current - period, and as long as the battery can deliver 100W then the lightbulb will shine.
What you *could* do is attach 5 100W lightbulbs in parallel and confirm that they all are bright and observe upon the addition of a 6th or 7th that there would be some diminishing brightness. That would confirm more or less you have a (5 to 6) * 8.3A ~=45A of supply current.
that wouldn't work, the battery would supply more current. the way you measure a car batteries output is by it's voltage level for rough estimates. hook up the 5 light bulbs and put a voltmeter in parallel, watch as the voltage drops from 13.5 volts at no load to 12.5~13 at rated amp-hour load to 11~11.5. that should tell you more or less how much power the battery can supply over a givin time, if you want more amps increase the number of light bulbs. car batteries charge to ~13.5 volts and are considered dead at 11.
I'm no expert, but I think this is incorrect. The resistance of the bulb remains the same when it's hooked up to 12V battery, therefore the current it draws should be 0.083 amps (i.e. 1/10th of what it draws at 120V).
This turns the bulb into a 1watt (12V * 0.083amps) bulb; i.e. its glow will be barely detectable.
a 60watt 120v bulb draws 7.2watts and is 20 ohms cold off of 12v so a 100watt bulb will draw about 10.2 watts cold.
MountainDew, The 45Amp your talking about is a per hour rating, meaning that your battery could give you a 45Amp current for one hour before it dies out.
About the second part of your question, when you take a 120Watt bulb and connect it to a 12V car battery, you can simply calculate the current drawn by the bulb from the relation P=VI, now since it's a 120Watt bulb and the car battery voltage is 12V the current drawn will be 10Amps, now since your battery can supply 45Amp for one hour then it can Supply 10Amps for 4.5 hours.
Wow! Lot's of misinformation here. An incandescent light bulb is not a linear device. The more current that flows through the bulb, the higher the resistance of the bulb gets. Also, why do you assume that no matter what voltage source you hook a bulb to it will automatically dissipate the rated wattage? The 120 volt 120 watt bulb will dissipate 120 watts AT THE VOLTAGE IT WAS DESIGNED TO OPERATE AT! It will NOT draw 10 amps, ever.
Averagesupernova, I think most of us assumed an ideal condition, we looked at it as a HW problem rather than the practical case.
The "ideal" condition wouldn't be holding the power constant, it would be holding the resistance constant.
i googled and learned to use the formula Watts x volts = amps, how are you getting 10 watts from a 100 watt bulb if you don't mind, from what I've read I've learned to do it like this.
100 watt bulb at 120 volts draws 100/120 = .8 amps
100 watt bulb at 12 volts draws 100/12 = 8.3 amps
or you could do watts like this for example:
.8 amps from 120 volts draws .8 * 120 = 96 watts per hour
8 amps from 12 volts draws 8 * 12 = around 96 watts per hour
the cold cranking amps on the battery is labeld 650 CCA or cold cranking amps, i would assume that would mean the battery could take a load of 6 100 watt bulbs for a very short period of time.
now that the battery is 650 CCA that would mean 650 * 12 = 7800 watt hours, which they are made to take loads like that for small amounts of time? if 45 amp hours was right then 45 * 12 = 540 watt hour, or 45 amp hour, same thing in my book.
so the question is what's the amp hours of the battery, i read on the internet the other day that the basic car battery holds about 45 amp hours, and i also read somewhere else last night that a basic car battery holds around 60 amp hours or 60 * 12v = 720 watt hours, meaning it could produce 720 watts in one hour and no more. i think marine batteries start at 100 amp hours and go up from there?
i need to get me a ohm or amp meter and learn to measure the ohms or amps to see more about this. by the way, i like this thread, I am learning lots about amps watts and volts.
if my 650 CCA battery in my truck was 650 amp ours, that would mean it was 7800 watt hours, if the battery produced that over time then that would mean it would run a 100 watt light bulb 7800 watts/100 watts = 78 hours, or 100 watt bulb on 12 volts uses 100/12 = 8.3 amps, so
650 amps / 8.3 amps = 78 hours, same formula as above giving the same hours, which i don't think 650 CCA is what you go by? funny how that works out.
i have a 12v battery on the bench and i hooked up a lightbulb to to test :P, cold i got 20 ohms from a 60 watt lightbulb, 60/100 = 0.6, 0.6*20 = 12, back to ohms law, 12 volts / 12 ohms = 1 amp, 1 amp * 12 volts = 12 watts (your right about me getting the wrong number the first time, must have pressed the wrong button lol:), so your 650 amp-hour batt would run a 100 watt light bulb for 65 hours. cca is different then amp-hours, see thread.
edit: let me add that because the resistance of a 100 watt house light bulb won't change the battery won't be dead for 650 hours, you won't get that 100 watts only 12.
MountainDew, resistance is a physical property of a resistor, so you need to use v=ir, find the new amperage and then plug that new amperage into p=vi to find the power at the lower voltage. A 100 watt bulb is labeled as such because the manufacturer assumes you wouldn't try to run it at any voltage other than what it was designed for, not because it would dissipate 100 watts at any voltage.
Though as said above, the resistance will be temperature dependent.
Also, watts is a rate already - there is no such thing as "watts per hour". You may mean watt-hours, which is watts times hours (not divided by, which is what "per" means)
russ_watters, Sorry, I didn't realize that it was a 120V bulb I thought it was a 12V bulb, now if it is a 120Volt bulb then things would be a lot different, first you would use \frac{P_1}{P_2} = \frac{V_1^2}{V_2^2} to get the new power drawn when connected to the 12V source, in this case it would be about 1.2Watt, as you properly realized this is not enough power to light the bulb, but it WILL draw some current anyway, so using the relation V=IR you get the current which will be about 0.1Amp, and since the battery gives away 45Amps for one hour it can give 0.1Amps for 450 Hours.
I have an idea that your car battery is capable of producing a heck of a lot more than 45A. When you first turn the key on it is probably producing thousands of amps for less than a second. The first thing you have to do is create a magnetic field in the starter. To electrial engineers this is called inrush, not to be confused with starting current. This will last for less than a second but can be extremely high. Once the magnetic field is created then the normal starting current is maintained. This could be in the area of 500A or higher but I am just guessing.
its not the burst of watts for a short time i care about, its the watts over a LONG period of time that the battery is capable of producing i am curious with. So i have another question on this if you guys don't mind. a 100 watt bulb on 120v ac uses .8 amps an hour, so this would mean if i hooked it to a car battery it would .8 * 10 since 1 ac watt = 10 dc watts? or would i pertend and do it this way.
100 watts * 12vAC = 8.3
8.3 AC AMps * 10 = 83 DC amps?
im still confused a little, I am not converting ac to dc or dc to ac, and for that i am confused of why dc amps diff from ac amps? THANKS
can one person clear this up since everyone has different numbers :smile:
lmao, this is halariouse, i do thank everyone for their help, and i do use this thread for reference. but dang, this is complicated.
I'll try to clear this up once and for all. There is no such thing as amps per hour. Amperes is already a rate. It is a given number of electrons passing one point in one second. The watt rating on a light bulb is the watts is dissipates AT THE VOLTAGE IT WAS DESIGNED TO BE USED AT. That's it. End of story. There is no more.
A normal resistor has an ohm rating. This is basically the ratio of voltage across the resistor to current passing through the resistor. Double the voltage and you'll double the current. Halve the voltage and you will halve the current. An incandescent light bulb is a bit different though. As the temperature of the filament increases, so does the resistance so the current does not rise linearly with the voltage as in the case of a normal resistor. Where you ever got the notion that dividing the voltage by 10 will multiply the current by 10 in order to keep the wattage the same I have no idea. It is totally incorrect.
Now for the amp-hours issue. First of all, find a bulb or load or whatever that is designed to be used at the battery voltage. Next, decide what type of battery is best suited for your load. In your case it is apparent that you will have the load on for more than a minute or 2 so go with a battery that has sufficient amp-hours. One amp-hour is 1 amp drawn out of a battery for one hour, or 2 amps for half an hour or half an amp for 2 hours. You get the picture. It's not a perfect graph though, a battery that is rated at 1 amp hour will not likely be able to supply 100 amps for 1/100th of an hour. This is where cold cranking amps comes in. You really don't need to worry about it since your load will be on for longer periods of time.
Now if this doesn't clear it up for you, don't get discouraged. We're here to help. But please don't think that because you googled and found a couple of formulas that you know how to implement them properly.
To amplify a little...
Just for clarity, do you happen to know how big of a factor that is? Ie, what the resistance is cold vs hot?
They were [incorrectly, obviously] assuming that a 100w light bulb would dissipate 100w regardless of the voltage across it. Obviously not how a resistor works...
I'm not sure why it hasn't come up, but there is also the issue of DC vs AC voltage for the light bulb. Regardless of all that, though, the simplest way to deal with this issue would be to use an inverter and power the light bulb the way it wants to be powered: with 120v AC power. Then you can simply ratio the voltage to find the amperage draw on the battery (not including losses in the inverter, of course...). So a 100W light bulb on an inverter attached to a 12V car battery will draw .83 amps from the inverter, which will draw 8.3 amps from the battery.
I don't know how big the factor is from cold vs hot on a filament russ. The cold resistance is a lot lower than most people think. It is usually assumed (mistakenly) that it is closer to the hot resistance. Measure it with an ohmeter cold and compute it hot (full voltage) and you'll have it.
On the inverter, don't forget to figure in the inefficiencies of the inverter.
The cold resistance of a 100w 120v lamp is around 10 ohms.
Quite small.
The hot resistance is 144 ohms @ 120v.
P=EI and E=IR.
No idea what the resistance might be at 12v, but probably fairly close to the cold resistance.
IIRC the old sealed beam automobile headlights were around 100W at 12v.
Don't know about the halogen variety.
Where I live, the legal limit for high-beams is 85W; for low-beams it's 55. Those laws were based upon incandescent bulbs, and have never been changed. (Needless to say, my lows are 85 and my highs 100, with 2 x 100W driving lights and a couple of 1,000,000 cp spots in reserve. :biggrin: )
Why didn't I think of that...?
...[...30 seconds later...]...
The resistance of a cold 100w lamp is about 10.3 ohms. So that means at start-up at 120V, it draws 11.6 A and would dissipate just under 1400w, if only for a tiny fraction of a second.
At 12V, it would draw 1.16A and dissipate 14w.
I know that the very common sealed beam lights used for 30 or more years will cause a 20 amp power supply to go into current limit. I've used them in various series/parallel to test power supplies at different loads. I can make and break contact enough on the power lead to cause the filament to heat up enough so that the power supply does not go into current limit mode. Then the power supply will light the bulb with ease. Gives an idea of how a filament can act. I also have a variac that I have used as a desk lamp light dimmer on many occasions but have never plotted the voltage/current relationship throughout the voltage range.
  • #31
#1 ac current is different than dc first off and foremost i am not going to go into the details as many different things fall into play such as the little thing that is called loss and many others.. for a 20 dollar bill ! you will turn on your own light! read this book and you will have the tools to do what you need ! and in a power outage you can have lights ect.. and you will not need to ask again here is a link to it... and yes i under stand that only a small percentage of you know about radio communication but the theory is the same... here is the link the book can be read in minimal amount of time less than a day enjoy or be in the dark http://www.arrl.org/catalog/?item=9531#top
  • #32
led lights would be a smarter choice way less draw
  • #33
This thread is a real muddle from beginning to end. The "45 Amps" marked on a battery must be 45 Amp Hours (not Amps per hour or anything else). That means you can get 1A for 45 hours or 5A for 9 hours or 0.5A for 90 hours. It doesn't actually imply that you could take things beyond 45A for 1 hour, though (the Amps times Hours doesn't extend beyond a 'reasonable' value of current drain). It is a single figure that tells you quite a lot about a battery, though.
Also, you can say nothing about how a light bulb's resistance will change as you alter the supply volts - it may vary by a factor of 10:1. Applying an appropriate voltage to a bulb, you can get any power you like (until it blows) but, except at its design voltage, you can't use it as a reliable measuring device. You need a 'heater' resistor, which will not change resistance over a large range of powers because it doesn't get white hot.
The answer to the original question is 45Ah divided by 8A =5.5 hours approx. But remember - taking more than half the charge out of a battery will compromise its lifespan. So you should really think in terms of 3 hours in practice.
  • #34
Do you realize how old this thread is and that you have simply repeated what has already been said?
And Taz, for the sake of resistors and light bulbs AC (using RMS voltage and current) is pretty much the same as DC. 100 volts RMS through a resistor will dissipate the same watt as 100 volts DC.
  • #35
really enjoyed this thread. Hate to beat a dead horse, but:
CCA= the amperage a battery can deliver at -18*C (or 0*F) for 30 seconds and maintain a terminal voltage above 7.2V.
Ah= Amp Hour Rating, which is the number of amps a battery delivers at 27*C (80F) for 20 hours and maintains a voltage above 10.5V.*
*The Ah indicates the battery's ability to supply power when, say, the alternator has failed.
  • #36
Well Done Mate! Thanks for ending this discussion! It really gave me a headache.
I actually won't take on anything anyone has stated as true. Best to obtain the manufactures Specs. on the battery. Rather than fool around with potentially deadly CAR Batterys.
*It is good for people to seek knowledge, but it's much safer to google the facts than try re-discovering the wheel.
*This wheel was spuare - not round. Thats why it took 3 years work to make it round, from many so called experts. And few with knowledge.
  • #37
Ok folks, this is freshman electronics. CCA is the measurement of the amount of amperage a battery can produce under extreme load. Amp Hours is the amount of amperage a battery can produce over a longer period of time at a lower load, say for instance a car radio.
RC is equal to approximately 1/5 of CCA.
Amp/Hours = (Reserve Capacity / 2) plus 16
I know this because I work for a data company and I have to test and certify every battery back up, every quarter, in every security panel and ups we have installed in the midwest. I learned it at ITT Tech.
  • #38
That, above, will be a rule of thumb for a particular battery. The "16" in the formula gives it away; it would not be the same for a large battery as for a small one.
  • #39
I just read all the posts in this four-year thread and feel much more knowledgeable with all the back and forth. My reason for following this thread is that I was hoping to find out how long my 5 24-V deep cycle batteries in series (for example) could power a 1,500-Watt SkilSaw after inversion to 120-V AC. Assuming no loss in the inversion process, I'm figuring the Saw will be drawing 12.5 Amps (1,500 / 120); but I'm still not sure how to figure out how long these fully-charged batteries can generate 12.5 amps without a recharge (from a solar panel or wind turbine).
  • #40
650 CCA means it can deliver 650 amps at peak capacity, which is only a few seconds. It does not mean you have 7800 watt hours. 650 doesn't say anything about how much watt-hour or amp-hour. You have to get that from the manufacturer directly because often the battery doesn't label them. I had this problem and had to go to the manufacturer's website to look up the detail specification. They list the amp-hour (AH).
A 650 CCA battery usually has about 10-14 Amp-hours.
There is no simple mathematical equation that relates the amp-hour to the Watt/Volt/Amp because the amp-hour is determined by a combination of the physical size of the battery as well as its chemical internal structure. In general, a bigger battery will have more amp-hour than a smaller one, but that relationship involves too many variables to calculate.
Once again check the manufacturer's website for the detail spec. You can't get the amp-hour from calculations or explanation of physics. The manufacturer determine the amp-hour by measuring the battery, not by calculation.
You can measure it too by turning on your car radio and see how long it lasts :)p
If you know the watt. of the car radio, the voltage of the battery, you can determine the amp. Multiply the amp with the hours that your car radio lasts, then you get the amp-hour. ;)p
  • #41
what's the make and model of the battery? google for that model and go to manufacturer's site.
From my preliminary google for "24v deep cycle battery" I've found that they range as much from 14AH to 100AH, depending on the size.
since you connected the batteries in series in order to achieve 120 volts, the AH capacity of the entire system will be the same as the capacity of a single battery. So find out that AH from the manufacturer and divide by the 12.5 amps that you've already figured out. That will give you the hours it last.
  • #42
You are missing the point that averagesupernova made a few msgs back
a 100W bulb is designed to draw/use 100W AT 120V NOT 12V, at 12V its resistance is going to be somewhat higher that its going to draw next to nothing and its probably not even going to glow.
a 100W bulb for 12V is going to have a very different cold and hot resistance than a 100W bulb at 120V
ok hunted around the house for a couple of globes closest in wattage I could find ...
40W 240VAC globe (we have 240V mains here in Oz) and a
20W 12V globe
cold resistance of 40W globe = 100 Ohms
cold resistance of 20W globe = 5 Ohms
On a 13V supply the ...
40W 240V globe drew 53mA (no Glow)
20W 12V globe drew 320mA (normal bright glow)
there's my 2 cents worth
cheers
Dave
  • #43
interesting...
that 20W globe ...
13V x 320mA = 4.1W maybe its been mislabelled will have to try and find another 12V rated globe for a test :)
Dave
  • #44
You cannot expect cold filament ohmeter readings to reflect wattage.
  • #45
Why not use auto bulbs (say 100W worth) and just measure current? If it's that vital to know the actual capacity of the battery then test it under real conditions. But mind you don't let it dip much below 12V or you will start to damage the battery.
  • #46
hello, i am going to do my project work on automatic hydraulic jack which will be driven by an electric wiper motor.for this wiper motor it requires of 100 watt to operate and requires a torque of 40 nm so can the vehicles battery power can provide that sufficient amount of power to this wiper motor?your help will be very grateful to me.
  • #47
The torque is not directly linked to the power. With appropriate gearing, you can get any torque you want because Power is Torque times Speed. If your motor uses 100W (when not stalled), does it produce 40nm at normal speed as opposed to requiring 40nm? How fast do you need the jack to operate? If the speed of the jack operation is not critical then you can use pulleys and a coupling belt between motor and pump to get the gearing you need to match the motor torque..
  • #48
just to lift thevehicle of around 4 to 5 tons from the hydraulic jack which is now a days generally operated by manually but i m just trying to transfer the rotation of wiper motor to the to and fro motion that is linear motion by linkages such as quick return mechanism,slider crank mechanism and by the calculation we did we just need the wiper motor which can provide the torque to the linkage arm of aroubd 50nm with the speed of 38 rpm that is at lowest speed which can obtaiin that power is torque*speed which forms the value of around 100 watt and this motor has to be driven from the vehicles internal power so i would want to know that can the vehicle internal power or vehicles battery can provide that sufficient amount of power to the vehicle??i hope you have understood what i n trying to say so please ur answer or suggesion will be very grateful n helpful to me thank you
  • #49
Yes, a car battery can provide 100W for a decent amount of time.
