What causes the acceleration of a car's suspension after hitting a road bump?
  • Thread starter Thread starter Oerg
    Car
The discussion centers on a quiz question regarding the acceleration of a car's suspension after hitting a road bump, which is expected to follow simple harmonic motion (SHM). The quiz incorrectly states that the variation of acceleration with time is a straight line, while the correct representation should be sinusoidal, as indicated by the equation a = -w²x₀sin(wt). Participants highlight that while the acceleration-displacement graph is a straight line with a negative gradient, the acceleration-time graph should not be linear due to the oscillatory nature of SHM. Damping effects in real suspensions complicate the motion, but the fundamental principles of SHM suggest that a straight line cannot accurately depict acceleration over time. The consensus is that the quiz question may have been misworded or misunderstood.
Oerg
Ok, I was stumped by this simple online quiz which asked the variation of acceleration with time of a suspension unit of a car after a road bump which follows SHM. (HC0809)
A. Straight line
B. Ellipse
C. Circle
D. Parabola
The answer was supposed to be sinusoidal and the quiz gave the answer as A, straight line but that is obviously wrong since
a=-w^2x
And the correct form is
a=-w^2x_0sinwt
Am i missing something, is the quiz wrong
Was that the exact wording? Maybe there is something you've missed...
Real suspensions also have damping and under particular conditions the oscillation is barely observable... but I don't think a "straight line" would ever be correct for the acceleration.
nooooooo... the acceleration-displacement graph is a negative gradient straight line, through origin. and the equation is a = -w^2X0
at least this is what we learn in high school...
If you graph acceleration vs. displacement it is indeed a straight line
with a slope of -w^2, as given by his equation a=-w^2*x
However that's not what he was asked for, unless he read the question wrong. Maybe the question made that slip up
yes there was damping mentioned in the question but I don't see how a straight line could every beformed if the graph was an acceleration time one
