Cauchy-Reimann from first principles
  • Thread starter Thread starter gtfitzpatrick
gtfitzpatrick
Prove from first principles that f(z) = \overline{z}^2 is not differentiable at any point z ≠ 0
So i guess i Have to show \stackrel{lim}{h\rightarrow0} \frac{f(z+h)-f(z)}{h} is equal to zero right?
\frac{\overline{z+h}^2-\overline{z}^2}{h} but not sure where to go from here.
Do i use z=(x+iy) then \overline{z} = x-iy and so \overline{z}^2 = x^2-y^2-i2xy
No, you need to prove that it does not exist. Start by formulating "limit does not exist" in the epsilon-delta language.
You could assume the limit exists (and hence f is differentiable), and calculate it twice using two sequences which converge to zero, and find that you get two different limits. In this case, your assumption becomes false, so f isn't differentiable.
You do know that the definition of differentiability you have is equivalent to having the limit
\lim_{n\rightarrow\infty}\frac{f(z+x_n)-f(z)}{x_n}
exist for every (complex!) sequence x_n\rightarrow 0, right?
In this case, I recommend you work with the definition you have, and see what happens when you approach zero along these two sequences:
x_n=1/n
y_n=i/n.
In general, such an approach is usually the best way to show that something -isn't- differentiable. Unless of course you have the Cauchy-Riemann equations :)
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
