How Does an Explosion Affect the Center of Mass in Projectile Motion?
In summary: Therefore, in summary, the distance x_cm from the mortar to the center of mass of the exploded pieces is equal to sqrt[(4/5)r^2 + d^2]. This is true regardless of the value of r, as long as the conditions given in the problem hold (i.e. negligible air resistance and explosive charge). I hope this helps with your homework problem. Best of luck!
pez
Hi, I was hoping to gather some feedback for one of my homework problems. Any help would be much appreciated. The problem is as follows:
A mortar fires a shell of mass m at speed v_0. The shell explodes at the top of its trajectory as designed. However, rather than creating a shower of colored flares, it breaks into just two pieces, a smaller piece of mass (1/5)m and a larger piece of mass (4/5)m. Both pieces land at exactly the same time. The smaller piece lands perilously close to the mortar (at a distance of zero from the mortar). The larger piece lands a distance d from the mortar. If there had been no explosion, the shell would have landed a distance r from the mortar. Assume that air resistance and the mass of the shell's explosive charge are negligible.
"The two exploded pieces of the shell land at the same time. At the moment of landing, what is the distance x_cm from the mortar to the center of mass of the exploded pieces?"
We're supposed to express it in terms of r. I had no problem w/ the second part of the problem, which wants us to express x_cm in terms of D. That was merely (4/5*m*d)/m, since the other component of the center of mass had a position of 0. I'm stumped on how I can approach the problem expressing it in terms of r, however. The hint given was that "The explosion only exerts internal forces on the particles. The only external force acting on the two-piece system is gravity, so the center of mass will continue along the original trajectory of the shell," which I didn't really find helpful. The position of the first piece would still be 0, wouldn't it? So wouldn't that just leave us with (4/5)*r/m ? This, however, is incorrect.
Edit: After thinking about it some more, would x_cm merely be r?
Edit2: Sweet, it is. Thanks for looking.
Hi there,
I can provide some insight into this problem. First, let's define some variables for clarity:
- m = mass of the shell before explosion
- v_0 = initial speed of the shell
- (1/5)m = mass of the smaller piece after explosion
- (4/5)m = mass of the larger piece after explosion
- r = distance from the mortar to where the shell would have landed without explosion
- d = distance from the mortar to where the larger piece lands after explosion
- x_cm = distance from the mortar to the center of mass of the exploded pieces
Now, let's consider the problem in terms of conservation of momentum and energy. Before the explosion, the shell has a certain momentum and energy, given by:
- p = mv_0 (momentum)
- E = (1/2)mv_0^2 (energy)
After the explosion, the two pieces will have a combined momentum and energy, given by:
- p' = (1/5)m(0) + (4/5)m(v_0) = (4/5)mv_0 (momentum)
- E' = (1/2)(1/5)m(0)^2 + (1/2)(4/5)m(v_0)^2 = (2/5)mv_0^2 (energy)
We can see that the momentum is conserved, but the energy is not. This is because some of the energy is lost in the explosion. However, we can still use the conservation of momentum to find the velocity of the center of mass of the two pieces after the explosion:
- p' = (4/5)mv_0 = (m')(v_cm) (where m' is the total mass of the two pieces and v_cm is the center of mass velocity)
- Therefore, v_cm = (4/5)v_0
Now, let's consider the motion of the center of mass. We know that it will continue along the original trajectory of the shell, so its horizontal displacement will be equal to r. However, we also know that it will have a vertical displacement equal to d, as the larger piece lands at that distance from the mortar. Using the Pythagorean theorem, we can find the distance x_cm from the mortar to the center of mass:
- x_cm = sqrt(r^2 + d^2)
- Sub
Hi there,
It seems like you have already arrived at the correct answer, which is great! The key concept to understand in this problem is the conservation of momentum. When the shell explodes, the total momentum of the system (shell + explosive charge) remains the same, but it is now distributed between the two pieces.
The hint given about the internal and external forces is trying to convey that the explosion does not change the total momentum of the system, but only redistributes it within the system. This means that the center of mass will still follow the same trajectory as the original shell, which is why the position of the first piece is still 0.
Using this understanding, we can see that the center of mass will be located at a distance r from the mortar, since the total mass of the system is still m and the position of the first piece is 0. Therefore, x_cm = r.
I hope this helps clarify any confusion and good job on solving the problem! Keep up the good work.
Related to How Does an Explosion Affect the Center of Mass in Projectile Motion?
What is the center of mass?
The center of mass is the point in a system where the mass is evenly distributed in all directions. It is the average position of all the mass in a given object or system.
Why is the center of mass important?
The center of mass is important because it helps us understand the overall motion and stability of a system. It is also a useful concept in physics and engineering for analyzing the forces acting on an object.
How is the center of mass calculated?
The center of mass can be calculated by finding the weighted average of the positions of all the individual masses in a system. This can be done using a mathematical formula or by physically balancing the system on a pivot point.
Can the center of mass be outside of an object?
Yes, the center of mass can be outside of an object. This can happen when there is a non-uniform distribution of mass in the object, or when there are external forces acting on the system.
What is the difference between center of mass and center of gravity?
The center of mass and center of gravity are often used interchangeably, but there is a subtle difference. The center of mass is the average position of mass in a system, while the center of gravity is the point where the force of gravity can be considered to act on an object. In most cases, the two points will be in the same location, but they may differ in situations where there are non-gravitational forces at play.
