Center of Mass w/ variable density
The discussion centers on calculating the center of mass for a box with variable density defined by the equation ρ = ρ₀(z²/c²). The user initially calculates the mass but is confused about how to apply the center of mass formula, particularly the integration process. Clarifications reveal that the center of mass requires three separate triple integrals for the x, y, and z coordinates, each incorporating the density function and the respective coordinate. The user ultimately confirms their understanding of the integration process and the need to correctly account for the density's dependence on z in their calculations. The conversation concludes with the user expressing gratitude for the assistance received.
scorpius1782
A box with one corner at the origin and the opposite corner at (a,b,c). The density is:##\rho=\rho_o\frac{z^2}{c^2}##
##r_{cm}=\frac{\int\vec{r}dm}{\int dm}##
I calculated the mass:
##\int_{0,0,0}^{a,b,c}\rho_o\frac{z^2}{c^2}=\frac{abc\rho_o}{3}##
But I'm not sure what the top of the equation is suppose to mean. Am I suppose to multiply the density by the direction it is changing (z) then integrate? I can't find an example anywhere that explains it well enough so that I can understand.
Thanks for the help.
Top (numerator?) of which equation?
It asks for the centre of mass, so that requires three co-ordinates. In vectors, ∫ρ(r)r.dv/mass
E.g. to get the x-co-ordinate, ∫ρ(x,y,z).x.dxdydz/mass.
so I would need to do:
##\int_0^a\rho_o\frac{z^2}{c^2}x dx##
##\int_0^b\rho_o\frac{z^2}{c^2}y dy##
##\int_0^c\rho_o\frac{z^2}{c^2}z dz##
Am I understanding correctly then?
edit: also, by top equation I meant the position integral. I should just solve these 3 integrals and then divide by the mass then.
No, each one is a triple integral, dxdydz.
That is
\int_{x=0}^1\int_{y=0}^1\int_{z= 0}^1\rho_0\frac{z}{c}dzdydx
By "Fubini's theorem" that can be written as a product of integrals:
\dfrac{\rho_0}{c}\left(\int_{x=0}^1 dx\right)\left(\int_{y= 0}^1 dy\right)\left(\int_{z= 0}^1 z dz\right)
HallsofIvy said:
That is
This has me confused. It appears like my first equation but with (a,b,c) replaced with (1,1,1) and you've dropped the squares for z and c. Is this suppose to be another method to find the CM?
haruspex,
So, I should have something that looks like:
##\int_0^a\int_0^b\int_0^c\rho_o\frac{z^2}{c^2}x dxdydz##
##\int_0^a\int_0^b\int_0^c\rho_o\frac{z^2}{c^2}y dxdydz##
##\int_0^a\int_0^b\int_0^c\rho_o\frac{z^2}{c^2}z dxdydz##
which would give me ##\hat{x}+\hat{y}+\hat{z}## all divided by the mass I found?
If I understand it correctly now:
##\int_0^a\int_0^b\int_0^c\rho_o\frac{z^2}{c^2}x dxdydz=\frac{\rho_o}{c^2}\frac{a^2c^2b}{4}=\frac{\rho_oa^2b}{4}##
so for ##\hat{x}## I would get ##\frac{\frac{\rho_oa^2b}{4}}{\frac{\rho_0abc}{3}}##
Which is just## \frac{3a}{4c}\hat{x}##
Yes.
I don't understand the plus signs. Each integral gives you one co-ordinate of a vector.
That doesn't look right. The dz should still be giving you a factor 1/3.
Likes 1 person
Ack, I forgot to square the z's for integration. Don't know why I did that. But, I get the gist so I'll be good from here. I just did plus instead of commas.
Thanks for all the help!
  • · Replies 19 ·
