Find Center of Mass: Attached Problem
The discussion focuses on finding the center of mass for a system of three uniform masses. Initially, the clarity of the masses' positions was questioned, but after clarification, it was established that each mass has its own center of mass located at its midpoint. The user calculated the distances from a reference point, initially miscalculating the distance for the third mass. After correcting the distance to 10m for mass 3, the user recalculated the center of mass, arriving at a final value of 6.67m. The conversation emphasizes the importance of accurately measuring distances when determining the center of mass.
jacy
hi,
I am finding the center of mass in this problem. I have it as an attachment. Please take a look, thanks.
Your attachment shows three masses, but I can't tell their positions from what's written. (It's just not clear to me.)
Here is that file again. Thanks for your help.
OK, now it's a bit clearer. The first thing to realize is that the masses are not point masses, but have length. Assuming that they are uniform, each mass has its own center of mass, right at its center. When calculating the center of mass of the system, you need to measure the distance of the center of each mass from your reference point.
Give it another shot.
Thanks again, so the distance for mass 1 will be 1m from my reference point, for mass 2 it will be 6m, for mass 3 it will be 8m. Am i correct.
center of mass = (20(1) + 30(6) + 40(8))/ 90
= 5.78 m
Recheck the distance to the cm of the third mass.
Measured from the left edge of mass 1, I'd say that your distances are correct for masses 1 and 2, but not for mass 3.
Thanks, the distance for mass 3 will be 10m from the left edge of mass 1, correct.
center of mass = (20(1) + 30(6) + 40(10))/90
= 6.67 m
This will be the answer, thanks for ur help.
