Finding the Center of Mass for a Pinewood Derby Car
To determine the center of mass of a pinewood derby car, one effective method is to balance the finished car on a knife edge or hang it from a string at multiple points to find the intersection of the lines that pass through the center of mass. Calculating the center of gravity (CoG) for each component and summing them can also be useful. It is recommended to place weight as low and as far back on the car as possible to enhance performance. Additionally, minimizing wheel friction through proper lubrication is crucial, followed by considerations of weight distribution and aerodynamics. Overall, achieving an optimal design involves balancing these factors for the best racing outcome.
bart Sherer
I am trying to determine the center of mass of a pinewood derby car. Any suggestions on how this can be done?
On paper, my measuring the shape and mass of each component - calculating their individual CofG then calculating the overall value.
Or just balance the finished car on a knife edge.
Thanks. There is also a lot of discussion as to where the weight in the car shoud be placed. I assume the weight should be placed as low as possible and as far back on the vehicle as possible. Your input is appreciated.
Hang the car from the middle of a string, the hanging (free) end of the string will pass through the cm. Do this from 2 different points, the intersection is your cm.
To find the center of mass, you actually need *3* different 'hangings' because the car is 3-dimensional. Two will identify the line that passes through the center of mass, the third will reduce it to a point.
In any case, IIRC, the number 1 design consideration is the wheel friction. The wheels must spin freely and be lubricated. Then, the weight and aerodynamics come into play.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
