Calculating the Center of Mass of a Boat with 3 People
To calculate the center of mass of the boat with three people, the formula x = (m_1*x_1 + m_2*x_2 + m_3*x_3) / M is used, where M is the total mass. The masses of the individuals (A, B, and C) and the boat need to be correctly positioned relative to a reference point, such as the front of the boat. The distances from the front to each person must be accurately measured, and the mass of the boat should also be included in the calculations. A diagram can help visualize the setup and clarify the distances involved. The total mass of the system is 580 lb, and the center of mass calculation must reflect the correct distances from the reference point.
Susanne217
Lets image the following a boat has three people in it
A has a mass of 120lb
B has a mass of 180lb
C has a mass of 160lb
and the boat has a mass of 120lb
also distance from person A to the front of the boat is 2 feet and distance from person A to person B is 8 feet and distance from person B to person C who is at the end of boat is 8 feet. What is the center of mass of the boat
x = (m_1*x_1 + ...+ m_n * x_n)/M
where is the mass of all 3 people and the boat.
the center of mass is then
x = \frac{120lb \cdot (2) + 180lb \cdot (8) + 160lb \cdot 16 }{120+180+160+120}
Is this right?
Make sure you measure the distance of each mass from the same point--for example, from the front of the boat. And don't forget the mass of the boat itself--where is it located?
What I'm unsure about is the distance from each end of the boat is exactly 8 feet to the center of the boat is the mass of the boat by any chance the mass at the center of the boat + the mass of boat??
Which means is the mass at the center is 180lb and mass of the person is 120lb
then the mass of the boat is 300lb?
and I multiply this by 8 this to the top of center of mass fraction is previous post??
The mass of the boat is given as 120 lb. But the center of the boat is not 8 feet from the end. Hint: Use the distances given to figure out the length of the boat. (And the correct distance of each person from the end.) Draw yourself a diagram.
Consider this a rudimentary ascii of the boat and its passengers:
(F) is the front of the boat, ABC are the people and (B) is the back,with each hyphen(-)marking 1ft
(F)--A--------B--------C(B)
120 180 160
and we know that the boat is of mass 120lb, so that can be added where?
make sure you do what the Doc says and always calculate moments from the same point =].
