Centre of Mass of carpenter's L square -
The discussion focuses on calculating the center of mass of a carpenter's L-square by dividing it into two rectangles. The upper rectangle measures 14 cm by 4 cm, while the lower rectangle is 4 cm by 12 cm. Initial calculations for the coordinates of the center of mass yielded (3.8 cm, 5.8 cm), but the y-coordinate was identified as incorrect due to miscalculating the height of the upper rectangle. After clarifications, the correct approach involves adjusting the y-coordinate to account for the height of the lower leg, leading to a revised y-coordinate of 6.85 cm. The conversation emphasizes the importance of accurately determining the centroid positions and using the correct coordinate system for calculations.
wizzle
A carpenter's square has the shape of an
"L," as shown at the right. Find the
coordinates of its center of mass, assuming
it to be made of uniform, material. (Hint:
divide the L-shape into two rectangles.)
MaXa+MbXb/(Ma + Mb)
I separated the L shape into two rectangles, with the upper part of the L being a rectangle of 14 cm x 4 cm, and the lower part of the L is a rectangle measuring 4 cm by 12 cm. I found the centre of mass of the upper rectangle to be (2,9) and of the lower rectangle to be (6,2). For the mass, since it's of uniform material, I used the area as its mass (not sure if that's right). The technique I tried was to first find the x-coordinate of the object's centre of mass:
(2x56)+(6x48) / (56+48) = 3.846 cm
For the y coordinate I used the y values of each rectangle:
(9 x 56)+(2x48) / (56+48) = 5.77 cm
So the centre of mass I got was (3.8 cm, 5.8 cm). Were the steps I used sensible?
Thanks a lot!
-Lauren
The x is correct, the y is wrong. You are calculating it with respect to the bottom of the L. Is the y-coordinate of the centroid of the upper rectrangle then equal to 9?
Note: you can check your answer by considering two different rectangles. One large one that covers the entire L, substracted by a smaller one that is enclosed within the legs.
Ahh...thank you. Since I separated the two at y=4 cm, then the upper rectangle is 14 cm high. Should I have put
(7x56)+(2x48) / (56+48) = 4.69 cm for the y coordinate? Thanks for your help!
The upper is indeed 14 cm high, and if considered alone, its centroid would be at y = 7 cm. However, since there is a horizontal leg element as well, and you place the coordinate system in the lower left corner of the L, the centroid of the upper retrangle moves up by 4 cm, which is the height of the lower leg. See this webpage for some illustrations.
Hi! Thanks a lot for attaching that link, it really helped. I think I've got it this time, since I'm using the right coordinates -
(11x56)+(2x48) / (56+48) = 6.85 cm
I appreciate your time srvs!
Pleasure. To double-check you could different rectangles as well. Haven't got a picture but if you consider a rectangle that spans from the most bottom-left corner of your L, and across the entire L then its dimensions are 18 by 12. The rectangle between the legs of the L is 14 by 12, so you could also say that with respect to the bottom of the larger rectangle, y = [ (14+4)/2 * (14+4 * 12) - (4 + 14/2) * 14 * (12 - 4) ] / [ (14+4 * 12) - 14 * (12 - 4) ] = 6.85 cm. So you consider instead the surface area and y coordinate of the large rectangle and substract from that the surface area and y coordinate of the smaller one.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
