How to Calculate the Angle of Shifting for a Rotating Disc with Removed Portion?
In summary, the problem involves a uniform circular disc with a radius of 2 cm and a circular portion of radius 1 cm being removed to maximize the shift in the center of mass. The disc is then rotated about its center 'O' by an unknown angle. Given that the magnitude of the displacement of the new center of mass is 1/sqrt(3) cm, the question asks for the angle of shifting, with the answer being 120 degrees.
d_vsuresh
From a uniform circular disc of radius 2 centimeter( its centre of mass is at 'O') , a circular portion of radius 1 cm is removed such that shift in centre of mass is maximum.The disc is now rotated about about 'O' perpendicular to the plane through an angle then the magnitude of displacement of new centre of mass is 1/square root of 3 centimeter. Then the angle of shifting is how much ?
Answer given as 120 degree.
Hi d_vsuresh! :wink:
Show us what you've tried, and where you're stuck, and then we'll know how to help! :smile:
To calculate the angle of shifting for a rotating disc with a removed portion, we can use the formula for the displacement of the center of mass:
Δx = xcm * sin(θ)
Where Δx is the displacement of the center of mass, xcm is the distance from the center of mass to the axis of rotation, and θ is the angle of rotation.
In this problem, we are given that the magnitude of the displacement of the new center of mass is 1/sqrt(3) cm. We also know that the radius of the original disc is 2 cm and the radius of the removed portion is 1 cm. Since the center of mass is shifted by the maximum amount, we can assume that the center of mass of the removed portion is at the edge of the disc, which means that xcm = 1 cm.
Substituting these values into the formula, we get:
1/sqrt(3) = 1 * sin(θ)
Solving for θ, we get θ = 120 degrees.
Therefore, the angle of shifting for the rotating disc with a removed portion is 120 degrees. This makes sense since the removed portion is exactly one-third of the original disc, so rotating it by 120 degrees would result in the maximum displacement of the center of mass.
What is the definition of centre of mass?
The centre of mass is the point at which the entire mass of a body or system can be considered to be concentrated.
Why is the centre of mass important?
The centre of mass is important because it helps us understand the motion and stability of objects. It is also used in calculations to determine the effects of external forces on a body or system.
How is the centre of mass calculated?
The centre of mass can be calculated by finding the weighted average of the positions of all the particles that make up a body or system. This can be done using mathematical equations or by physically balancing the object on a pivot point.
What is the difference between centre of mass and centre of gravity?
The centre of mass refers to the point where the mass of an object is concentrated, while the centre of gravity refers to the point where the force of gravity on an object is concentrated. In a uniform gravitational field, the centre of mass and centre of gravity will be the same point.
How does the centre of mass affect the stability of an object?
The lower the centre of mass of an object, the more stable it is. This is because the centre of mass is the point around which an object's weight is balanced. An object with a lower centre of mass is less likely to topple over when disturbed.
