Centrepetal Force & Inclined Plane
The discussion revolves around two physics problems involving forces on an inclined plane and rotational motion. For the first problem, a block is pushed up a 22-degree slope with an initial velocity of 1.4 m/s and a coefficient of friction of 0.70, but the user struggles with setting up the equations to determine how far the block travels before stopping and whether it will slide back down. The second problem involves a wet sock in a slowing washing machine drum, where the user seeks to find the drum's rotation rate when the sock falls, using the equation mg = (mu)mv^2/r to analyze the forces involved. Participants emphasize applying Newton's second law and the correct setup of equations to solve these problems. Overall, the thread highlights the challenges of applying physics concepts to real-world scenarios.
Grogerian
I Have two questions one of them i just can't start it, I don't understand what it is I'm supposed to set up or how.
A Block is shoved up a 22 degree slope with an initial velocity of 1.4 m/s the coefficient of friction is .70 how far up the slope will the block make it? once stopped will it slide back down?
Fg = mg
Fa = ma
4 kinematic equations?
well i drew out my FBD and i have tried
Fg(incline) = mgSin(22)
Fn = mgCos(22)
Ffr = (Mu)mgCos(22)
And from there... I'm stuck, i do however have no idea how i can solve this i tried doing
m(-9.81)(Sin(22)) = -(.70)(-9.81)(Cos(22))m
but mass cancels and your ending up with no unit's which I Am assuming is incorrect, i just don't know what equations i need to set up for this problem :(
Problem 2
A washing machine’s drum is rotating rapidly (about its vertical axis). A wet sock is stuck on the inside, halfway up
the drum. The drum begins to slow its rotation. How many rotations per second is the drum making when the sock falls to
the bottom of the drum? The coefficient of friction between the sock and the drum is 0.13, and the drum radius is 0.35 m.
ac = v^2/r
Circum. = 2.166
all i really want to know is am i correct in saying
mg=(mu)mv2/r
if not, i will reattempt, at least using that my mass is not needed :)
Problem 1:
Apply Newton's 2nd law to solve for the acceleration: ΣF = ma.
Problem 2:
mg=(mu)mv2/r
That is a correct statement of the condition for the sock to fall.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
