Centrifugal force on rotating blades
To calculate the centrifugal force on airfoil blades at constant angular speed, determine the average force along the blade and multiply it by the blade length to find the total force at the root. This can be simplified by estimating the center of mass and treating the forces as concentrated at that point, using the formula CF = Mass × Omega² × Radius. The discussion also mentions a "Maximum regulating test" for axial fans, which has a limit of +/- 15,000 kilo-pounds, though details on its execution are sought. Understanding these calculations and tests is crucial for assessing blade performance under rotational forces. The conversation highlights the importance of accurately determining forces in rotating systems.
wisemo
Hi everyone,
I've got a set of airfoil blades here which are homogenious and have a constant profile (x-section). Each blade is of equal length (as should be).
What would the best way be to calculate the centrifugal force on the blade root as a result of constant angular speed? say o - rads/s
I've just gotten a little confused about involving the 'centre of gyration'.
thanks
mo
If you can calculate the average force throughout the blade, and multiply by the length of the blade, that will give you the total force, all of which is felt at the root of the blade.
Easy, since blade is constant section, estimate the centre of mass position and treat the root forces/stresses as if the mass was concentrated at the mass centre - ie CF = Mass.Omega^2.Radius.
I have recently came across a test - "Maximum regulating test" with a limit of +/- 15000 kilo-pound been performed on axial fans. Can anyone explain me what this test is all about & how it is performed.
Thanks in advance.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
