What is the Centripetal Acceleration of a Car on a Circular Curve?
  • Thread starter Thread starter robvba
    Acceleration
The centripetal acceleration of a car negotiating a flat circular curve with a radius of 50 m at a speed of 20 m/s is calculated using the formula A_c = V^2/R. Substituting the values, the calculation yields 8 m/s². The maximum centripetal force provided by static friction is noted but does not affect the calculation of acceleration directly. Some participants express confusion over the relevance of additional details provided in the problem. Ultimately, the focus remains on the straightforward application of the centripetal acceleration formula.
robvba
A car is negotiating a flat circular curve of radius 50 m with a speed of 20 m/s. The maximum centripetal force (provided by static friction) is 1.2 × 104 N. What is the centripetal acceleration of the car?
MAc = MV^2/R
20^2 / 50 = 8 m/s^2 ?
MAc = MV^2/R
Not sure, but I think you're right. I have no idea what the second sentence actually means, but it might just be a red herring. Cent acc is just velocity squared over radius, and they gave you that in the first sentence.
