Chain rule of partial derivatives
xkellyy
Suppose f(x,y) = 2x^5 + 4xy + 2y^3
g1(u,v) = u^2 - v^2
g2(u,v) = uv
h(u,v) = f(g1(u,v), g2(u,v))
Use chain rule to calculate:
dh/du (1,-1) and dh/dv (1,-1)
i let h (u,v) = 2(u^2 - v^2)^5 + 4(u^2-v^2)(uv) + 2(u-v)^3
then i tried drawing a chain rule tree diagram:
h --> f --> g1 and g2
g1 --> x and y
g2 --> x and y
so dh/du = (dh/df . df/dx . dx/du) + (dh/df . df/dy . dy/du)
then i got stuck :S
help please?
Stuck how?
im not sure if my chain rule is correct to begin..i found this in my textbook though on calculating partial derivatives with changes in variables:
dh/du = dh/dg1 . dg1/du + dh/dg2 . dg2/du
so i followed that instead...
and got this
since h (u,v) = 2(u^2 - v^2)^5 + 4(u^2-v^2)(uv) + 2(u-v)^3
dh/dg1 = 10(u^2-v^2)^4 + 4uv
dg1/du = v
is that right so far?
h is just a different name for f(g1(u,v), g2(u,v)), so the factor of dh/df in your original attempt is unnecessary.
Since you wrote out h(u,v) explicitly in terms of u and v, you can simply differentiate it as you normally would do to find the answer you should get.
What's probably confusing you are all the variables. So try it like this:
h = f(g_1, g_2) = 2g_1^5 + 4g_1g_2 +2g_2^3so\frac{\partial h}{\partial g_1} = 10g_1^4 + 4g_2and then express the g's in terms of u and v. (This gives you what you got above.) Do the same thing with g2. Then put those together with the partial derivatives of the g's to form the final result. (You got \partial g_1/\partial u incorrect.)
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
