Solve Min Velocity for Ball Not to Touch Hemispherical Rock
  • Thread starter 012anonymousx
  • Tags
    Challenge
In summary, to ensure the ball doesn't touch the rock, the minimum initial speed must satisfy the condition: m * v^2/R > mg.
012anonymousx
47
A person standing at the top of a hemispherical rock of radius R kicks a ball (initially at rest on the top of the rock) to give it a horizontal velocity v.
What is the minimum initial speed to ensure the ball doesn't touch the rock?
x^2 + y^2 = r^2
y = -0.5gt^2 + R
R - (gx^2)/(2v^2) > sqrt(R^2 - x^2).
The left side is eqn for parabolic trajectory, the right is the boulder
After a lot of math you get something like this:
(g^2x^4) / (4v^4) + gRx^2 / v^2 + x^2 > 0
Now I am super confused about this part:
For some reason, the claim goes like, as x approaches 0, we get the tightest limit, therefore it needs the largest curvature at the start and it will pass the boulder (reasonable I guess..).
THEN for some reason, 1 > gR / v^2
I have no idea where this came from.
See here; http://minerva.union.edu/labrakes/2_D_Motion_Problems_Solutions.pdf
Another solution I read was;
m * v^2/R > mg
Fc > Fg.
Why...? The acceleration into the boulder has to be GREATER than gravity?
That doesn't make a lot of sense to me :(
At first glance, ISTMT you need the ball to travel at least R metres horizontally in the time that it takes to fall R metres vertically.
Related to Solve Min Velocity for Ball Not to Touch Hemispherical Rock
1. What is the formula for calculating minimum velocity for a ball not to touch a hemispherical rock?
The formula for calculating minimum velocity for a ball not to touch a hemispherical rock is v = √(rg), where v is the minimum velocity, r is the radius of the rock, and g is the acceleration due to gravity.
2. How do you determine the radius of the hemispherical rock?
The radius of the hemispherical rock can be determined by measuring the diameter of the rock and dividing it by 2. Alternatively, if the volume of the rock is known, the radius can be calculated using the formula r = (3V/4π)^(1/3), where r is the radius and V is the volume.
3. What is the significance of the minimum velocity for a ball not to touch a hemispherical rock?
The minimum velocity for a ball not to touch a hemispherical rock is the threshold velocity at which the ball will roll over the rock without touching it. This velocity is important to know in order to prevent collisions between the ball and the rock in various scenarios, such as in sports or engineering designs.
4. Does the weight of the ball affect the minimum velocity required?
Yes, the weight of the ball does affect the minimum velocity required. The heavier the ball, the higher the minimum velocity needed to overcome the force of gravity and prevent it from touching the hemispherical rock.
5. Can the minimum velocity for a ball not to touch a hemispherical rock be calculated for objects other than a ball?
Yes, the same formula can be used to calculate the minimum velocity for any object not to touch a hemispherical rock, as long as the object is rolling and the surface of the rock is smooth. This includes objects such as cylinders or spheres of different sizes and weights.
