How Do You Calculate Display Readings from Pressure in a Cream-Filled Silo?
To calculate display readings from pressure in a cream-filled silo, the relationship between gauge pressure and fluid height must be established. The pressure sensor, located 0.6 m above the base, measures the pressure exerted by the cream, which has a density of 850 kg/m³. An equation can be derived using the hydrostatic pressure formula, P = ρgh, where h is the height of the cream above the sensor. To calibrate the display, an offset must be applied to account for the sensor's height, ensuring accurate readings. If water is used instead, the silo's height must be adjusted to ensure the display reads 100% when full, requiring further calculations based on the different densities.
joe98
A 150 m^3 silo(cylinder) (12 m high) is used to store cream (density 850 kg m-3). An electronic pressure sensor (measures gauge pressure) is mounted 0.6 m up from the base of the tank, and a 0 to 100% display is used to indicate the level. It is not possible to sense
the level once it is below the sensor, but the display can be calibrated with a constant
offset to account for this extra fluid (for example, the sensor can show 10% when
there is no pressure). Derive an equation to relate the display reading (in %) to the
sensor pressure. What offset should be used on the display to account for the 0.6 m
mounting height? If water is used instead of cream, how high must the silo be in
order for the display (calibrated for cream) to read 100% when the silo is full?
P=F/A
P=ρ+ρgh
ρ=m/v
Q=Av
I have no idea where to start where can I start with ok
m=ρV=850/150=5.7kg
I am not sure how to derive an equation to relate the display reading (in %) to the
sensor pressure.
Any clues guys
cheers
would I be able to use Bernoullies principle on this question?
