Challenging question think you're smart enough?
  • Thread starter Thread starter plane
The discussion presents a physics problem involving two masses, m1 and m2, connected on a frictionless incline. When released, m2 falls 2.5 meters and m1 moves up the incline before being launched as a projectile. Participants are encouraged to solve the problem by showing their work and providing answers. The thread also includes a dismissive comment about doing one's own homework, indicating a mix of engagement and reluctance to assist. The focus remains on the physics concepts of inclines and projectile motion.
plane
challenging question! think you're smart enough?
here is a very good questioninvolving inclines and projectile motion. please answer in full show your work and answers.
A small mass m1=2.0kg, sits on a frictionless incline attached to a heavy mass m2=10kg. when the system is released, m2 falls 2.5m then sticks to the ground, while m1 travels up the incline and is then launched as a projectile. determine the altitude w.r.t the ground reached by m1. (assume smooth transition as m1 leaves the incline.)
No, I'm not going to fall for that. Do your own homework!
