Chance for a foreign-born engineer
  • Thread starter Thread starter redgoat
    Engineer
Foreign-born aerospace engineers face challenges in securing positions within the U.S. aerospace industry and federal government organizations, primarily due to citizenship and security clearance requirements. Many federal jobs are inaccessible without U.S. citizenship or a green card, limiting opportunities significantly. Private aerospace companies, such as Cessna and Boeing's civilian divisions, offer better prospects for foreign nationals. U.S. citizenship or a green card alleviates discrimination concerns in hiring, although obtaining necessary security clearances can still pose challenges. Overall, while opportunities exist, navigating legal and regulatory hurdles is essential for foreign-born engineers.
redgoat
Does a foreign-born aerospace engineer have a difficulty in finding a position in aerospace industry or federal government organizations in U.S?
In terms of a federal or government position, most likely, yes. Unless you have established yourself here with either a green card or citizenship, many federal positions may not be available to you. That is not to say that it is impossible. It would simply limit your options in places you could go and positions you could serve. In my location, for example, foreign nationals of any kind can not even look at certain machinery without our legal department ensuring certain export licensing is in place.
Regular private aerospace companys that don't have government programs would probably be your best bet. Companies like Cessna or possibly the civilian liner side of Boeing.
How about a foreign-born engineer with U.S citizenship or Green Card?
If you're a US citizen, I'm pretty sure it's illegal to discriminate in hiring.
Getting security clearance (if that is needed for the position you're applying) may be another case, though.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
