Change in an expression that I don't understand
  • Thread starter Thread starter mkerikss
    Change Expression
The discussion centers on understanding the equivalence of two expressions involving vector differentiation. The key point is the application of the product rule for differentiation, which is valid for vector dot products. The expression d\vec{v}/dt * \vec{v} can be shown to equal d/dt(1/2\vec{v} * \vec{v}) by using the product rule. This results in the formulation that includes both terms of the vector's derivative. The explanation clarifies the mathematical reasoning behind the equivalence.
mkerikss
In the answer to a homework I didn't understnad why these are the same:
d\vec{v}/dt*\vec{v}=d/dt(1/2\vec{v}*\vec{v})
Can someone explain?
The product rule for differentation applies, even if it is a vector dot product that is being differentiated. Therefore:
\frac{d}{dt}\left(\frac{1}{2}\vec{v} \cdot \vec{v}\right) = \frac{1}{2}\vec{v}\cdot \frac{d\vec{v}}{dt} + \frac{1}{2}\frac{d\vec{v}} {dt}\cdot \vec{v}​
Thank you:smile:
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
