Change in the order of integration in triple integrals
The discussion revolves around changing the order of integration in triple integrals, specifically examining an equation involving integrals with limits defined by variables. Participants are analyzing the validity of the equation based on their calculations of the left-hand side (L.H.S.) and right-hand side (R.H.S.) integrals.
  • Mixed
  • Participants are attempting to solve the L.H.S. and R.H.S. of the equation, raising questions about the validity of their results and the integration process. There are discussions about the implications of integrating with respect to an unknown function and the necessity of changing the order of integration.
The conversation is ongoing, with participants providing insights and corrections regarding the integration process. Some have suggested that changing the order of integration may be necessary, while others are clarifying the limits of integration and addressing potential mistakes in previous calculations.
There is an emphasis on the unknown nature of the function f(x), which complicates the integration process. Participants are also considering how the limits of integration change when altering the order of integration.
WMDhamnekar
MHB
Show that ##\displaystyle\int_a^b\displaystyle\int_a^z \displaystyle\int_a^y f(x) dx dy dz = \displaystyle\int_a^b \frac{(b-x)^2}{2} f(x) dx ##
Hint: Think of how changing the order of integration in the triple integral changes the limits of integration.
No equation
If we solve the L.H.S. of this equation, we get ## \frac{(b-a)^3}{6}## and if we solve R.H.S. of this equation, we get ##-\frac{2b^3-3ba^2 +a^3}{6}##
So, how can we say, this equation is valid?
By the way, how can we use the hint given by the author here?
Please show your work.
Solving L.H.S. of the equation ## \displaystyle\int_a^b\displaystyle\int_a^z\displaystyle\int_a^y f(x) dx dy dz = \displaystyle\int_a^b\displaystyle\int_a^z (y-a)f(x) dy dz##
## L.H.S. = \displaystyle\int_a^b \left( \frac{y^2}{2}-ay \big |_{y=a}^{y=z}\right) dz##
##L.H.S.= \displaystyle\int_a^b \frac{z^2}{2}-az -\frac{a^2}{2}+ a^2 dz ##
## L.H.S. =\frac{z^3}{6}-\frac{az^2}{2} -\frac{a^2z}{2} + a^2z \big|_{z=a}^{z=b}##
## L.H.S.= \frac{b^3 -3ab^2 +3a^2b -a^3}{6}= \frac{(b-a)^3}{6}f(x)##
In this way, if we solve the R.H.S. of the given equation, we get ##-\frac{2b^3 -3a^2b +a^3}{6}f(x)##
In this way, if we solve the R.H.S. of the given equation, we get ##-\frac{2b^3 -3a^2b +a^3}{6}##
Your first equality is wrong. You cannot integrate ##f(x)## with respect to ##x## and end up with ##x f(x)## and then not insert the boundaries into ##f(x)##. Then you arbitrarily remove ##f(x))## in the next step.
If you evaluate both expressions for ##f(x) = 1## then they both evaluate to ##(b-a)^3/6##.
Then , how to answer this question using the given hint?
First, do you understand why you cannot reasonably perform the integral over ##x##?
Yes. Because I could not insert the upper and lower limits of integration into f(x) and get the final answer to integrate it w.r.t. y
No, because ##f(x)## is unknown, you do not know what the primitive function is and cannot perform the integral in the first place. The function ##x f(x)## is generally not a primitive function of ##f(x)##.
So, since you cannot integrate with respect to ##x##, you will need to change the order of integration to get rid of some of the integrals. Note that ##f(x)## is not a function of ##y## or ##z## so it can be taken out of those integrals. As alluded to by the hint, when you do a change of the order of integration, you need to consider how this affects the integration boundaries.
Don't even think to perform integration with respect to x, you shouldn't (since the result to prove doesn't perform it either) and you can not since function f(x) is totally unknown.
Instead you can perform easily integration with respect to y and z but you first must find out how the limits of integration for y and z change if you put y first and z second (or z first and y second, they are different in each case).
So, to answer this question, we have to integrate in this way ##\Rightarrow \displaystyle\int_a^bf(x)\displaystyle\int_x^b\displaystyle\int_x^z 1 dy dz dx= \displaystyle\int_a^y \frac{(b-x)^2}{2}f(x) dx ##
Isn't it?
WMDhamnekar said:
So, to answer this question, we have to integrate in this way ##\Rightarrow \displaystyle\int_a^yf(x)\displaystyle\int_x^b\displaystyle\int_x^z 1 dy dz dx= \displaystyle\int_a^y \frac{(b-x)^2}{2}f(x) dx ##
Isn't it?
You got it almost correct, you correctly find out the limits for y and z but the limits for x are not entirely correct, I hope it is a typo from you.
Thanks for pointing out my mistake. I have corrected it now.
There is a general method to safely change order of integration or summation. First write all of the ranges as inequalities, i.e.,
$$ a \leq x \leq y $$
$$ a \leq y \leq z $$
$$ a \leq z \leq b $$
Combine them into a single chain of inequalities, i.e.,
$$ a \leq x \leq y \leq z \leq b $$
Break that apart. If you want to integrate or sum over x last then start by writing
$$ a \leq x \leq b $$
Then deal with y and z.
