How Does Changing Variables Simplify Nonlinear PDEs?
Changing variables can simplify nonlinear partial differential equations (PDEs) by transforming them into a more manageable form. In the provided example, the original PDE is transformed by introducing the new variable x = s - t, leading to a new equation that incorporates partial derivatives with respect to time and the new variable. The chain rule is applied to derive the relationships between the derivatives of U with respect to s and t, allowing for the substitution of derivatives in the original equation. However, the discussion indicates that simply substituting these derivatives does not yield the desired simplified equation, suggesting the need for a different approach. Understanding these transformations and their implications is crucial for effectively solving nonlinear PDEs.
aquarian11
I need guidance regarding PDE.
If u have a nonlinear PDE as
Ut+Us+a*U*Us*b*Usss=0
where U is function of (s,t) and a,b are constants.
by introducing new variable x=s-t we will get
Ut+a*U*Ux+b*Uxxx=0
Ut means partial derivative w.r.t time
Us means partial derivative w.r.t s.
How can we get the second equation from the first one?
Mathematics news on Phys.org
By using the chain rule.
U_s= U_t \frac{\partial t}{\partial s}+ U_x\frac{\partial x}{\partial s}
Note: if you are going to use x= s- t to replace s only, you will need to think of s as a function of the other variable, t.
If x= s- t, then s= s+ t so both partial derivatives are 1:
U_s= U_t+ U_x[/itex]<br /> U_ss= (U_t+ U_x)_s= (U_t+ U_x)_t + (U_t+ U_x)_x= U_tt+ 2U_tx+ U&lt;br /&gt; _xx<br /> <br /> Similarly, <br /> U_sss= U_ttt+ 3Uttx+ 3Utxx+ Uxxx<br /> Sustitute those into you equation.
Subsituting these , will not give me the desired equation.
I have solve it, same concept of chain rule but with different approach.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
