Is Frequency Doubling the Secret to Producing Red Light in Laser Pointers?
  • Thread starter Thread starter EspangeBob
Changing light frequency without altering its direction is not feasible; any attempt to do so typically results in a loss of directionality. Light can experience a change in wavelength when transitioning through different media, but the original wavelength is restored upon exiting. Non-linear processes, such as frequency doubling, can generate higher harmonics, but they require specific conditions and do not maintain direction. Fluorescence is a related process where a photon of shorter wavelength is absorbed and a longer wavelength photon is emitted, but this also results in a loss of direction. Ultimately, achieving frequency change while preserving direction remains unattainable with current methods.
EspangeBob
Is it possible to change light wave frequency via a media filter?
or if it is impossible is there any why to do it?
without changing light direction !
Welcome to the PF. :smile:
To change the light frequency, you would normally need some non-linear process to generate higher harmonics or to modulate the frequency of the light. Is that what you are asking about?
When light changes media as it propagates (like when it goes from air to glass), the frequency stays the same but the propagation velocity changes (so what happens to the wavelength?).
And what do you mean by "media filter"? :smile:
Remember conservation of energy. The energy of a photon is proportional to frequency.
So the power out of a passive filter is the power in, minus any absorption or reflection.
Likes berkeman
It is not possible to change the frequency of light without loss of direction.
Light can reduce it's wavelength slightly while propagating through slower materials such as glass, but the original wavelength is restored when the light exits the material.
The closest analogy to your “wanted” effect is fluorescence, where a molecule excited by a shorter wavelength photon then releases a lower energy photon with longer wavelength. But the direction information will be lost during the quantum conversion.
Can you explain better what you are trying to accomplish?
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
