Programs Changing my major, not sure which physics to take?
The discussion centers on a student transitioning to Chemical Engineering and deciding between General Physics I and Honors Physics I. General Physics I is a large, calculus-based course with a competitive grading curve, while Honors Physics I offers a more in-depth exploration of similar topics in a smaller class setting. Participants suggest that the Honors course may enhance problem-solving skills and provide better access to instructors, despite its increased difficulty. The student expresses some intimidation regarding the Honors textbook but is encouraged to consider the benefits of smaller class sizes and collaborative learning. Consulting an academic adviser is also recommended for personalized guidance.
antonisz
Hello everyone,
After long deliberation I decided that my major isn't for me, I would rather do Chemical Engineering.
I have taken Algebra Physics I and II and gotten A's in both. I have the option of taking General Physics I or Honors Physics I.
General Physics I is a calculus-based introductory course primarily for chemistry, engineering, and physics majors. Covers kinematics, Newton's laws, energy, momentum, rotational motion, and oscillations. The textbook they use is https://www.amazon.com/dp/111823071X/?tag=pfamazon01-20 by David Halliday and Robert Resnick. The class has a size of 450 students. The grading is the Top 10% get an A, the next 10% a B, and so on.
Honors Physics I covers the same topics as http://undergrad-catalog.buffalo.edu/coursedescriptions/index.php?abbr=PHY&num=107eneral Physics I, but in greater depth. This course is intended for potential physics majors, students in the Honors College, and advanced students in other majors (with permission from the instructor). It is especially appropriate for students who have taken AP Physics C in high school. It will cover similar topics as General Physics I but with several significant differences. The class will be taught at a level comfortable for students who would receive a B or higher in a typical http://undergrad-catalog.buffalo.edu/coursedescriptions/index.php?abbr=PHY&num=107eneral Physics class. Because of the higher average GPA of students in this class, grading will be adjusted to reflect this quality, rather than following the conventional curves used for http://undergrad-catalog.buffalo.edu/coursedescriptions/index.php?abbr=PHY&num=107eneral Physics. Introductory materials, such as review of trigonometry, vectors and calculus, in http://undergrad-catalog.buffalo.edu/coursedescriptions/index.php?abbr=PHY&num=107eneral Physics will not be covered. This leaves room to expose students to a wider range of interesting applications of Newtonian mechanics, and recent developments in topics such as relativity and cosmology. The class size is limited, to encourage interactive learning and communications between students and the instructor. There are 15 class spots in this course. The textbook used in this course is Classical Mechanics by MorinMy friend says that Honors is better because it will help teach problem solving and critical thinking better than the regular class, but I must admit I am a little intimidated by the textbook that is being used.
I have taken Calculus I and II, and along with physics I will be taking Calculus III, Differential Equations, and a language class.
Thank you and best,
I would recommend General Physics.
antonisz said:
Hello everyone,
Thank you and best,
That depends on you and the type of student you are.
You can probably learn much more from the honors course then you can from the general physics course. that being said it will be more difficult, so if you are the type to start flailing when you get into deep water you may be in for a rough semester. In the honors course you will also get the benefit of small class sizes!
Likes Dr. Courtney
So it is the same subject, one is honours and the other is not. Well, nothing to add for people here as this is all about what type of student you want to be, not about something that helps you transition to chem eng.
I'd go with the honours course on the basis that, with 15 students, even if you start having a hard time, you'll get decent access to the lecturer for help, and at least some of the 15 will probably form a study group or something and you'll all get to know each other quite well and be able to help each other.
Plus the grading seems fairer since it's not a dumb rigid curve where if you're ranked 45 you get an A but 46 and you get a B (unless I've misunderstood).
Likes donpacino
antonisz said:
Hello everyone,
Thank you and best,
I have a rather obvious question, and one that hasn't been suggested yet: Have you asked your academic adviser?
Zz.
Likes Dr. Courtney
Hey, I am Andreas from Germany. I am currently 35 years old and I want to relearn math and physics. This is not one of these regular questions when it comes to this matter. So... I am very realistic about it. I know that there are severe contraints when it comes to selfstudy compared to a regular school and/or university (structure, peers, teachers, learning groups, tests, access to papers and so on) . I will never get a job in this field and I will never be taken serious by "real"...
Yesterday, 9/5/2025, when I was surfing, I found an article The Schwarzschild solution contains three problems, which can be easily solved - Journal of King Saud University - Science ABUNDANCE ESTIMATION IN AN ARID ENVIRONMENT https://jksus.org/the-schwarzschild-solution-contains-three-problems-which-can-be-easily-solved/ that has the derivation of a line element as a corrected version of the Schwarzschild solution to Einstein’s field equation. This article's date received is 2022-11-15...
