Charge accumulation using radiation
  • Thread starter Thread starter mooreppj
    Charge Radiation
The problem involves a small insulated copper sphere illuminated by radiation with a wavelength of 300 nm, and it asks for the maximum charge accumulation on the sphere. The subject area includes concepts from electrostatics, particle physics, and the photoelectric effect.
  • Participants discuss the relevance of the equations for energy, flux, and surface area in relation to charge accumulation. There is uncertainty about how irradiance influences charge on an insulated object, and whether the copper substrate could play a role in charge generation. Some participants question the applicability of the photoelectric effect at the given wavelength and explore assumptions regarding the uniformity of radiation.
The discussion is ongoing, with participants sharing insights and calculations. Some have expressed doubts about the feasibility of charge accumulation under the given conditions, and there is recognition of the potential for the question to be misleading or improperly framed. No consensus has been reached, but several productive lines of inquiry have been suggested.
Participants note the lack of explicit information regarding the type of radiation and its effects, as well as the absence of time considerations in the problem statement. There is also mention of the work function for copper and its implications for the photoelectric effect, which may limit the applicability of certain approaches.
mooreppj
Hello! I've been working on this physics problem for a physics II course and I'm stumped. Maybe someone can assist?
A small insulated copper sphere of radius 0.001m is illuminated with radiation with wavelength 300nm. What is the maximum charge accumulation on this sphere?
The only equation I can do unit analysis on and get a coherent answer is E = hc/λ
I'm not sure which equation to use next, however I think that:
E = kq/r^2
is an important equation for this problem.
Finally, the surface area of a sphere:
A = 4[itex]\pi[/itex]r^2
Initially, I calculated the energy associated with the radiation:
E = hc/λ = hc/(3e-7) = 6.62e-19 J
Then, I divided the sphere's surface area (A = 4[itex]\pi[/itex]r^2 = 1.26e-5 m^2) to get a flux (also apparently called irradiance) of light over the sphere's surface.
Flux = 5.27e-14 J/m^2
Now, I'm not sure how to proceed. I'm having difficulty conceptualizing how irradiance influences charge on an insulated object. I thought that in order for charge to accumulate on an insulated object, an electric field must be present. My understanding is that light is electrically neutral and by itself does not create electric fields. Could the copper substrate be significant in creating a charge through being ionized? I feel like that point is beyond the scope of the question but I'm completely lost on how to proceed.
Thanks for any help anyone can offer!
Hello mooreppj, and welcome to PF. Lovely problem you are faced with. If your rendering is complete, some assumptions might be necessary. You judge if that's nonsense or not.
First, if you illuminate with radiation and they are asking for a maximum charge: what kind of radiation ?
I'm glad to see that (after some skirmishing with equations) you pose the question as well. Good. My instinct (proven to be good sometimes, worthless at other times) tells me you've been introduced to some kinds of radiation in the preceding chapter already. Met your new friends α, β, and γ. Originally I naively hoped that the middle one would do the trick. No way. Wavelengths 300 nm are for photons only. No idea how they can charge a 1 mm copper pellet?
So it's down to you: what's the context? What's the preceding chapter about ? Are we doing electrostatics here (like: kinetic energy has to overcome potential difference). Something else ? Photoelectric effect, for instance ?
I'm intrigued, puzzled and interested.
Can only be photoelectric effect. Photons knock out electrons until potential > Ekin max.
Hey BvU, thanks for responding so quickly!
I'm certainly willing to use some assumptions if they're reasonable. That's the question as written unfortunately, so I think SOME assumptions need to be made. I don't think there is anything particularly novel about the radiation used. If I've made an assumption, it is that the radiation uniformly irradiates the sphere from all directions. I applied this assumption when I divided by the surface area of the sphere to get the flux of photons per squared meter.
Other than that though, I can't think of any other assumptions that are reasonable to solve the question.
We've recently done several chapters on particle physics, nuclear physics, and introductory quantum physics. We've only used electrostatics insomuch to describe charged particle phenomenon such as kinetics with electrons, protons, neutrons, and the particle zoo. I don't think there are any waveforms from nuclear particles though because the radiation is in the ultraviolet spectrum.
When he asks for the maximum charge accumulation on this sphere, I wish I could be more specific. We've done material surrounding blackbody radiation, the photoelectric effect, compton, de broglie, etc etc. I'm sure you get the gist.
As the question is asked though, when I see "accumulation" I think energy balance:
dQ/dt = Charge in - Charge out,
Where because the sphere is insulated, would not release any charge to the environment and
dQ/dt = Charge in
But the fact that nothing is mentioned in the question about time kind of stops that thinking in its tracks. I also can't figure out how, as the question is written, 300nm radiation is charging anything. I feel like if I flashed a UV light all around a copper pellet in a dark room, it wouldn't ever get a charge. Could this be a trick question?
I should also note that I don't think the photoelectric effect applies for a copper sphere at this particular wavelength. Using the following equation for the photoelectric effect:
Kmax = hf - θ
Where theta is the work function. In this case, it is copper which my text ( Serway & Jewett, 9th ed.) says is 4.70 eV. Doing all the math to solve for frequency:
f = c/λ = 9.993e14 hz
And solving Kmax,
Kmax = (6.626e-34) x (9.993e14) - [(4.70 eV) * 1.602e-19 J/eV]
Kmax = -9.089e-20
The Kmax being negative tells me that the wavelength of the radiation is too long to remove electrons from the surface of the copper sphere. In fact, if I solve for the cutoff wavelength:
λ(cutoff) = hc/θ
λ(cutoff) = 264 nm
I think I understood what your point was though; that if the electrons could be ejected from the surface the sphere, the charge on the sphere would be equal in magnitude to the charge of the electrons ejected. However I don't think that it works in this case for the reasons I worked out above.
At first I thought this might be a nice problem involving the photoelectric effect with photons knocking electrons out of the copper. After some calculation, I have some doubts. Were you given a work function value for copper?
[EDIT: oops, I see you have already addressed this!]
Dear mooreppj: Congrats! You have rummaged through the information given, done some checks that convinced you this can't work (λcutoff). You're not omniscient, so you can't be completely sure and the best statement you can make is exactly what you write down.
I found a comparable exercise (problem 28.13) but figured you were able to get through this on your own (I'm not omniscient either, but definitely lazy -- basically i missed the λ difference, so I didn't bother to actually do the calculation -- but what the heck).
So your question as written is either a trick question, or some oversight by a lazy teacher or exercise writer. I have strong views in both cases:
Trick questions are didactically treacherous except in direct communication, where body language can get things right. On paper, you just feel, well, tricked.
Lazy physicists aren't necessarily bad physicists (I surely hope ;-) because they tend to think a little longer before doing unnecessary work.
In this case you have risen well above the level of a simple exercise. Enough flattery by now, get back to work and tackle the next one!
Oh, and: if I turn out to be completely wrong I would more than appreciate a posting of what was supposed to come out!
  • · Replies 35 ·
  • · Replies 32 ·
  • · Replies 26 ·
