Charge given externally to a capacitor
  • Thread starter Thread starter EddiePhys
    Capacitor Charge
When a capacitor is charged to a potential difference V and then disconnected from the circuit, adding a charge Q to the positive plate results in a new potential difference. The initial assumption that the potential difference becomes V + Q/C is incorrect because the negative plate does not acquire an equal and opposite charge due to the disconnection. Instead, the correct potential difference is V + Q/2C, as the formula V = Q/C applies only when both plates have equal and opposite charges. The discussion emphasizes the need to consider the charge distribution and electric field within the capacitor to arrive at the correct answer. Understanding surface charge densities and their impact on the electric field is crucial for solving this problem accurately.
EddiePhys
A capacitor of capacitance C is charged to a potential difference v from the cell and then disconnected from it. A charge Q is now given to its positive plate. The potential difference across the capacitor is now?
V is the potential difference. Charge +Q is given and hence -Q is induced on the negative plate.
The potential difference should be V+Q/C
But the answer is V+Q/2C. Why?
There is no -Q induced on the negative plate since according to the problem the capacitor has been disconnected from the circuit; there is no path for charge to move onto or off of the negative plate. So there is only a +Q charge on the positive plate.
The formula ##V=Q/C## assumes equal and opposite charge on both plates. Since only one plate was charged here, it is only half of this value ##Q/2C##.
Likes EddiePhys
You can solve this formally as follows:
Assign surface charge densities σ1, σ2, -σ2 and σ3 to the two plates. The surfaces 2 and -2 face each other inside the capacitor. Make sure you understand why the inside surface charge densities have to be equal and opposite. Assume unity area. then you can write 3 equations in 3 unknowns and solve for all three surface charge densities.
Two of the equations are simply charge summation. For the third I'll give you a hint: what must the 3rd equation be in order to make the E field zero inside either plate?
Once you have surface charge densities inside the capacitor it should be straightforward to find the E field and integrate, with and without the extra charge.
PS the given answer is what I got.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
